I am stucked in miniture ROM> prompt and can not load IOS with my 2940 series switch.
I am stucked in miniture ROM> prompt and can not load IOS with my 2940 series switch. I copy xmodem the newest IOS to flash, but just can not load the IOS.  What should I ? Any suggestions?
4 ACCEPTED SOLUTIONS
Hello Grace,
Please post a transcript or a screenshot of your terminal session with the router while trying to boot it. There may be some vital information showing us where the problem may be.
Best regards,
Peter
Re:I am stucked in miniture ROM> prompt and can not load IOS wit
Download an older smaller feature reduced version and load that first. Once that is loaded upload your newer larger ios.
Sent from Cisco Technical Support Android App
Hello Grace,
The Cache Error Exception suggests that either the IOS image is corrupted, or - more seriously - that your switch has a hardware problem.
I would suggest the same what Jeff suggested as well - try using a less feature-rich IOS, ideally a different, older version to boot your switch. If that does not help then I am afraid we are out of luck here. Cache Error Exception suggests a memory or CPU issue.
By the way, do the numbers in the displayed register dump change each time you reload the switch? Also, can you use the 't' (test memory) function from the mini ROM?
Best regards,
Peter
Hall of Fame Super Gold
SR    = 0x10400004    CAUSE   = 0x00008000
EPC   = 0xffeffff7    ERR_EPC = 0x80c23610
BADVA = 0xebaddff7    CACHERR = 0x20023613
RA    = 0x80c247a8    SP      = 0x80c5c728
V0    = 0x00000001    V1      = 0x80c2cc00
A0    = 0x80c2da18    A1      = 0x80c2f108
This is a hardware problem.  Nothing you can do about it.
Hello Grace,
Best regards,
Peter
Hi! Peter:
Here is what on my screen when I power up the Catalyst 2940 Switch:
ROM>
ROM> ?
Commands:
  r    Read memory
  w    Write memory
  d    Dump memory
  t    Test memory
  c    Call address
  0    Dump CP0 regs
  q    Quit (return)
  ESC  Reset system
ROM>q
Returning to bfc01480
then nothing happen.  It is the same with all possible comment options in the list
Hi! Peter:
Here is the power on display:
C2940 Boot Loader (C2940-HBOOT-M) Version 12.1(13r)AY1, RELEASE SOFTWARE (fc1)
Compiled Mon 30-Jun-03 15:16 by antonino
WS-C2940-8TT-S starting...
Base ethernet MAC Address: 00:1b:8f:39:c9:c0
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7612416
flashfs[0]: Bytes used: 5120
flashfs[0]: Bytes available: 7607296
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Variable Block Filesystem (vb:) installed, fsid: 5
Loading "flash:/c2940-i6q4l2-mz.121-22.EA14.bin"...
    SR    = 0x10400004    CAUSE   = 0x00000000
    EPC   = 0xffffffff    ERR_EPC = 0x80c06610
    BADVA = 0xebafdff7    CACHERR = 0x20006612
    RA    = 0x80c06600    SP      = 0x80c5cec0
    V0    = 0x00000038    V1      = 0x80c30000
    A0    = 0x80c82894    A1      = 0x00000001
Mini Monitor (press ? for help)
ROM>
Please help!
Thanks!
Grace
Hello Grace,
Best regards,
Peter
Hi! Peter:
I boot it up again this morning.  Here is the out put.  I think it is the same as before I will do as you and Jeff suggested.  If it still is not working, I will let it go.  Thanks a lot!
Grace
    BADVA = 0xebaddff7    CACHERR = 0x20006612
ROM>
Hi! Peter:
I did you and Jeff suggested, copy xmodem a older version of IOS and boot it.  It did not load either.  I got the same error message as boot the previous version.  Then I did a few ROM> t.  All passed.   Here is the out put.  I am not sure I did correctly.
Thanks for all your help.
Grace
switch: boot flash:c2940-i6q4l2-mz.121-22.EA10a.bin
Loading "flash:c2940-i6q4l2-mz.121-22.EA10a.bin"...#
ROM> t
Start addr?
End addr?
Testing 00000000 - 00000000
Passed
ROM> t
Start addr? 01040000
End addr? 080c2f10
Testing 01040000 - 080c2f10
Passed
ROM> t
Start addr? 0ffeffff
End addr? 0ebaddff
Testing 0ffefffc - 0ebaddfc
Passed
ROM> t
End addr? 01040000
Testing 01040000 - 01040000
Passed
ROM> t
End addr? 0ffeffff
Testing 0ffefffc - 0ffefffc
Passed
ROM> t
Start addr? 0ebaddff
End addr? 0ebaddff
Testing 0ebaddfc - 0ebaddfc
Passed
ROM> t
Start addr? 080c247a
End addr? 080c247a
Testing 080c2478 - 080c2478
Passed
ROM> t
Start addr? 00000000
End addr? 00000000
Passed
ROM> t
Start addr? 080c2da1
End addr? 080c2da1
Testing 080c2da0 - 080c2da0
Passed
ROM> t
Start addr? 00000800
End addr? 00000800
Testing 00000800 - 00000800
Passed
ROM> t
Start addr? 080c2361
End addr? 080c2361
Testing 080c2360 - 080c2360
Passed
ROM> t
Start addr? 02002361
End addr? 02002361
Testing 02002360 - 02002360
Passed
ROM> t
Start addr? 080c5c72
End addr? 080c5c72
Testing 080c5c70 - 080c5c70
Passed
ROM> t
Start addr? 080c2cc0
End addr? 080c2cc0
Testing 080c2cc0 - 080c2cc0
Passed
ROM> t
Start addr? 080c2f10
End addr? 080c2f10
Testing 080c2f10 - 080c2f10
Passed
ROM>
Grace,
I am afraid the switch is fried. I am sorry about that.
Best regards,
Peter
350
