I have a dead 2621xm router in my schools simulated LAN
dmccalla1
Our 2621xm router is dead in our simulated LAN in the lab at my college. We have tried reloading the IOS several times and it is still dead. there is not prompt or anything it doesn't even try to boot from what I can tell. Any help you could give me would be greatly appreciated.
8 Replies 8
Collin Clark
Do your LED lights light up?
Can you console in and boot and see what the output is?
Yeah the LED's do light up. I am consoled in and when I press enter to enter into command line it does nothing it doesn't even try to boot.
If you stay consoled in and power cycle the router to you get any output?
No there is still no output
vaisharm
Hi Daniel
Are you sure if the console cable that you have is good? Also, what baud rate are you connecting at? Try 115200, 9600 and all other lower speeds and see if it helps.
~Vaibhav
yeah the console cable is good. I am connecting at 9600 and have tried other speeds and it doesn't make a difference either way
Daniel,
If the cable is good and you have tried all buad rates from the lowest to 115200, the router needs to be replaced.
~Vaibhav
Agree, sounds like it's completely dead.
