11-23-2009 08:58 AM - edited 03-06-2019 08:42 AM
my name is choong. i have been studying for ccna. i have a lab with 3 routers and 3 switches. the routers i have are 3640, 2 2610. the switches are 2900 xl series. i redo the ios on one of my 2610. i have 2 rom files when i did the ios how can i get rid of the old ios here is the ver of the router. can anybody help
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 10-Feb-05 02:11 by ssearch
Image text-base: 0x80008098, data-base: 0x80CD32C8
11-23-2009 09:05 AM
Hello Chong,
your system image is flash:?
you can see files in flash with
dir flash:
you can then delete a file with
delete flash:filename
you need then to squeeze to free space
squeeze flash:
I would copy the file again with a more meaningful name, this a quite common error during questions in copy tftp command
Hope to help
Giuseppe
11-23-2009 06:30 PM
k, i did what u say but the first file does not show when i type dir flash: . is the router suppose to have 2 files?
11-23-2009 07:01 PM
Choong,
Have you already loaded the IOS version you need? If yes, do a "sh flash all", you should see 2 files, one is your old one that you do not want and one is a new one that you want to keep. Then follow what Giuseppe posted and you should be fine.
Reza
