11-23-2009 05:38 PM - edited 03-06-2019 08:42 AM
Hi, there
What does it mean by below Err Msg ?
and What is the Bus Asic ?
Do you happend to have the architecture of WS-X6248-RJ-45 ?
ㅁ Verson : cat6000-sup2.6-4-13.bin
ㅁ supervisor : WS-X6K-SUP2-2GE
ㅁ Chassis : C6509
ㅁ Err Msg : %SYS-3-SYS_LCPERR3:Module 9: Bus Asic #0 out of sync error: Module requires attention - troubleshoot or contact TAC for assista.
11-23-2009 08:09 PM
The bus ASIC is used to send packets for lookup. The port ASIC handles transmission and reception for several physical interfaces.
Please try one of the following workaround and if it doesn't make the message disappear, open an SR for RMA request:
1- Try to reset the LC
2- Try to reseat the LC
Laurent.
11-23-2009 08:35 PM
Hi, Laurent Aubert
Is Port ASIC the Pinnacle ASIC or Coil ASIC ?
11-24-2009 06:02 AM
It's the COIL ASIC.
Laurent.
11-24-2009 04:52 PM
Hi, Laurent.
I appreciate your help.
By the way,
There are 4 Coil Asics on the WS-X6248-RJ-45.
If Port Asic is Coil Asic, a group of ports should not work.
However, All the user who connect to the ws-x6248-rj-45 didn't work.
11-24-2009 05:34 PM
The issue is on the bus ASIC shared by all Port ASIC's.
Laurent.
11-23-2009 08:10 PM
This error means that you need to contact Cisco TAC and organize for the blade in slot 9 to be RMA-ed.
ASIC stands for Applications Specific Integrated Circuit.
