03-11-2008 08:34 AM - edited 03-05-2019 09:40 PM
Hello, I have problem con switch WS-C3750G-24PS in Stack. this is a Sh ver
System image file is "flash:c3750-ipbasek9-mz.122-25.SEE4/c3750-ipbasek9-mz.122
25.SEE4.bin"
cisco WS-C3750G-24PS (PowerPC405) processor (revision F0) with 118784K/12280K b
tes of memory.
Processor board ID FOC1124Z6DC
Last reset from power-on
2 Virtual Ethernet interfaces
112 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:0D:CF:78:80
Motherboard assembly number : 73-10217-07
Power supply part number : 341-0108-03
Motherboard serial number : FOC112428DY
Power supply serial number : DCA1122A1WU
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3750G-24PS-S
System serial number : FOC1124Z6DC
Top Assembly Part Number : 800-26855-01
Top Assembly Revision Number : C0
Version ID : V05
CLEI Code Number : CNMWR00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
2 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
3 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
4 28 WS-C3750G-24PS 12.2(25)SEE4 C3750-IPBASEK9-M
Mar 10 22:00:52.187 UTC: PSECURE: Assert failure: psecure_sb->info.num_addrs <=
psecure_sb->max_addrs: ../switch/psecure/psecure_utils.c: 129: psecure_update_a
dress_counts (TCBB3750VDP5-4)
Mar 10 22:00:52.187 UTC: -Traceback= 6BB870 6C6CC4 6C883C 663C 7A18 4DE2AC 579E
8 57A038 909AAC 90000C (TCBB3750VDP5-4)
dress_counts (TCBB3750VDP5-3)
8 57A038 909AAC 90000C (TCBB3750VDP5-3)
dress_counts (TCBB3750VDP5-2)
8 57A038 909AAC 90000C (TCBB3750VDP5-2)
Mar 10 22:02:53.083 UTC: PSECURE: Assert failure: psecure_sb->info.num_addrs <=
Mar 10 22:02:53.083 UTC: -Traceback= 6BB870 6C6CC4 6C883C 663C 7A18 4DE2AC 579E
Anyone know what is this error?
Solved! Go to Solution.
03-11-2008 08:43 AM
In IOS 12.2(25)SEE[n] this traceback message will appear when reloading a Cisco EtherSwitch service module that is a member of a switch stack with port security enabled.
There is no workaround. This message can be ignored.
You can check this Open Caveats ID CSCsc55332
If you hate seeing this traceback message, try updating your IOS to the latest version. It "might" disappear.
Dandy
03-11-2008 08:43 AM
Dandy
