Webcast-Catalyst9k
I have to be missing something (connecting 2 routers)
I am trying to take down a old multilink connection that has 2 T1's  and just use a 100 mb copper connection to replace it.  I am having an issue when trying to connect via copper between two routers via RJ45. I keep getting the interface is up, line protocol is down.   Here are the configs of what I am trying to change. I am sure I am missing something basic.  Thank you for any help.
Router 1 2851: Start
interface Multilink1
description To Office
ip address 192.168.0.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/1
no ip address
duplex full
speed 100
Router 12851:After
no ip redirects
no ip unreachables
no ip proxy-arp
ppp multilink
shutdown
ip address 192.168.0.14 255.255.255.252
duplex full
speed 100
Router 2 3745: Before
description To Field
ip vrf forwarding ntl
ip address 192.168.0.5 255.255.255.252
ppp multilink
interface FastEthernet0/0
no ip address
duplex full
speed 100
Router 2 3745: After
ppp multilink
shutdown
ip address 192.168.0.13 255.255.255.252
speed 100
full-duplex
Purple
Can you let the gigabit interface on both sides autonegotiate speed and duplex instead of hardcoding it.
Alain
Are we sure those routers support auto MDIx ?
If they don't you'll need a crossover cable or some sort of hub/switch between them.
Purple
good point Brian, but 2851 supports auto MDIX and even if 3745 doesn't support it,only one side support is needed for autoMDIX to work as far as I know.The only caveat is that for auto MDIX to work we need autonegotiation  and it has been disabled here.
Alain
Re: I have to be missing something (connecting 2 routers)
Thanks for the info yes it was the cross over cable.  I feel like a moron. I knew it had to be something simple.
143
