Community Member
I'm looking for an application that I can use to manage Cisco fiber switches. Can I manage with Cisco Configuration Professional?
I'm looking for an application that I can use to manage Cisco fiber switches. Can I manage fiber switches with Cisco Configuration Professional or is there something better?
Thanks!
VIP Super Bronze
Use Solarwindshttp://www
Use Solarwinds
http://www.solarwinds.com/?gclid=CO3-lbfCk74CFcg7OgodXxYA5A&CMP=KNC-TAD-GGL-NA_BRAND-X-DL&ef_id=UeRQkwAAAIKkqFuU:20140505002421:s
Hall of Fame Super Gold
What are you trying to
What are you trying to achieve?  If the link goes down, the switch will send you an email?
Community Member
I would like to be able to
I would like to be able to manage all config options on the switches. Alerting would be nice to have as well.
Depending on the model of
Depending on the model of your switch, a feature called Embedded Event Manager (EEM) can enable the switch to send e-mails when a nominated link goes down/up.
I don't understand what you mean by "manage all configs".  You need to elaborate further.
Community Member
Hi Leo, By manage I mean to
Hi Leo,
By manage I mean to make changes to the interface config, vlans, shutdown ports, etc..
Thanks!
None.
127
