I need an advice in full connectivity between IPV4-IPV6 network
Dr.X
Level 2
Level 2
Hi ,
i have a network topology as attached.
as you see it has both ipv4 & ipv6
i just need an ideas here about how let all pcs (ipv4 & ipv6) to talk together based on the topology attached.
Bilal Nawaz
Hello Ahmed,
You can use BGP with address-family ipv4 to provide routing for ipv4 and address-family ipv6 for ipv6.
This means between your router's you will have 2 BGP peerings, one for v4 one for v6.
If you use the ipv4 address for bgp address-family ipv6, you will have to apply a route-map on neighbor to change the next hop address to the relevant ipv6 interface address.
hth
Bilal
CCIE #45032
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
thanks but im looking for simple answer like full dual stack or by using NAT protocol.
regards
