10-22-2010 03:01 AM - edited 03-06-2019 01:41 PM
Hi All,
i have an 4 switches in stack wise connection. there is a problem in one of the stack cable i need to change the stack cable between 1 & 4.
Do i need to switch off the switch in order to add a new cable to existing member switch..
10-22-2010 04:15 AM
Generally, you don't have to power-off any switch, while replacing stack cable.
I am not sure about the complete stack cable connections.
Please send "sh switch neighbor" with "sh ver | inc IOS"
- Yogesh
10-22-2010 04:45 AM
Hi Yogesh,
------------------ show switch detail ------------------
Switch/Stack Mac Address : 0013.1945.1080
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0013.1945.5600 1 0 Ready
*2 Master 0013.1945.1080 1 0 Ready
3 Member 0013.1945.1100 1 0 Ready
4 Member 0013.1945.3b80 1 0 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 Ok Down 2 None
2 Ok Ok 3 1
3 Ok Ok 4 2
4 Down Ok None None
10-22-2010 05:52 AM
I guess you are trying to replace the stack cable connected between Sw1-SP2<<==>>Sw4-SP1. If so, it shouldn't be a problem.
Did you notice the stack cable connection between Sw3-SP1 <<===> Sw4-SP2 ?
From the command results, I see Sw4 has no stack neighbors.
- Yogesh
10-22-2010 08:39 AM
Thx Yogesh..
Can i get any document that states we can remove the stack cable while switch was running...
Thaks again
10-25-2010 05:57 AM
I am not aware of any document that provides the details you requested.
Managing Switch Stacks - doc on CCO:
- Yogesh
10-22-2010 09:29 AM
Shouldn't be a problem just pulling one cable , the ring will wrap and run at half bandwidth I believe until the cable is replaced.
