I wnat know about REP,RSTP
Hi my name is Jo~
Qeustion
1. REP
I wnat to make ring topology that i use"ie-3000" switch.
How many switch can connected ring topology.
I consider REP protocol.
I know STP can connect 7 device in this topology.
2. REP Configuration example.
I find configuration example about REP.
3. How many switch can make ring topology?
1 REPLY
Hi Jo,
Hi Jo,
May be it's a bit late to answer your question.  I think there's no limit on the number of devices per ring. But you have to consider that the more devices you have, the slower the convergence  and response time due to failure.
Here is a good link to get started with REP.
http://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3000/software/release/12-2_50_se/configuration/guide/ie3000scg/swrep.html
99
