iBGP configured on loopback address not reachable
I have 2 routers connected, can ping each other on the F0/0 interfaces. Each has loopback interfaces which are the only once advertised in BGP (AS1).
Problem: I am not able to ping the loopback addresses.
Any ideas. This should be possible.
Config:
router bgp 1
synchronization
bgp log-neighbor-changes
network 1.0.0.0
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
R2#sh run | beg bgp
router bgp 1
synchronization
network 2.0.0.0
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
The routers can ping each other:
R2#ping 192.1.12.1
Sending 5, 100-byte ICMP Echos to 192.1.12.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/140/220 ms
What did I miss?
Debug message from R1:
*Mar 1 06:59:01.918: BGP: 2.2.2.2 active open failed - no route to peer, open a ctive delayed 29293ms (35000ms max, 28% jitter)
1 ACCEPTED SOLUTION
Re: iBGP configured on loopback address not reachable
Jacob,
What Mike was asking you to do is to establish BGP peering one of two-ways.
1. If you want to use loopback addresses to peer then you need to have a static or another IGP route (not BGP) to the far end loopback address. You would also need to reinstate the 'update-source' command that you removed. You need a config similar to this one;
R1:
ip route 1.1.1.1 255.255.255.255 192.1.12.1
R2:
ip route 2.2.2.2 255.255.255.255 (next_hop_ip)
2. Your second option is to reconfigure, on both routers, the "neighbor (physical_int_IP_address) remote-as 7000' to the physical interface IP on the far end device. This doesn't need any static/IGP routing as the peering IP addresses are directly connected.
Sundar
Silver
you can either add a static route to your loopbacks or change the update-cource loopback 0 to 'next hop self"
i.e.
neighbor 1.1.1.1 next hop self
bjw Silver
Silver
Are the loopback interfaces in the Ip Routing table of the applicable routers?
AFAIK
Sychronization will not allow the loopback0: to be advertised in BGP unless there is a route know by the igp?
Show a show ip route.
The adjacency between R1 & R2 does not come up because:
1) update-source Loopback0 tells BGP to establish a connection to/from it's Loopback0
2) BGP doesn't know how to reach the remote Loopback0
no route to peer, <=== this is the key message
There are two ways to correct this:
1) Best Practice - You'll need to configure either a static route or an IGP (RIP, OSPF, EIGRP, etc) to exchange the routes from Loopback to Loopback so that BGP can establish that connection.
2) Remove the update-source loopback0 clause from both routers' config. The connection will then be established from the directly connected interfaces. While this approach will fix your back-to-back router issue, it is generally not a recommended approach for real networks because of the potential for broken next-hop information and reliance on the directly connected interface for peering.
HTH,
Mike
Looks like I didn't type quickly enough - I'm late to the party... :-)
Thanks Guys
What I would like to achieve is the second option given by "mikedavi1"
I have removed "update-source loopback 0"
But I still cannot ping both ends via the loopback interfaces.
R2#sh run | begin bgp
router bgp 1
synchronization
network 2.0.0.0
neighbor 1.1.1.1 next-hop-self
no auto-summary
R2#sh ip route | begin Gateway
Gateway of last resort is not set
C 192.1.12.0/24 is directly connected, FastEthernet0/1
C 2.0.0.0/8 is directly connected, Loopback0
C 192.1.25.0/24 is directly connected, Serial1/0.25
R1#sh run | begin bgp
router bgp 1
synchronization
network 1.0.0.0
neighbor 2.2.2.2 next-hop-self
no auto-summary
R1#sh ip route | begin Gateway
C 1.0.0.0/8 is directly connected, Loopback0
R1#ping 2.2.2.2
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Any more ideas?
Jacob,
R1:
R2:
Sundar
Thanks, Sundar. I wasn't too clear about the fix.
Thanks everyone, I am well sorted out with this one now.
1.First of all for IBGP to work ur synchronisation must be disabled.
no synchronisation.
2. To work IBGP with loopback ip u have to route the loopback ip pointing towards other router.
R1:
R2:
Rate this if it works.
Thanks.
Yash
1685
