05-18-2009 06:09 AM - last edited on 03-25-2019 04:06 PM by ciscomoderator
We run DMZ and Internal network totally seperate, I have a business request to connect an IBM Enclosure to DMZ switch (as trunk) and to Internal network switch ( as trunk) so that some blades can talk to DMZ and some to internal network. If I have two set of switches ie 4 switches in the blade center, can I plug in two switches to DMZ and two to Internal. Is it even possible? I think IBM blade center architechture allows that I wanted to know if someone has done it here.
Thanks.
05-18-2009 12:11 PM
It's possible - at least with Bladecenter and Nortel L2/3 Copper switches. You configure the Nortel switch accordingly (trunk groups) and which ports that the internal Blades ports (typically 1-14) should be a member of.
05-18-2009 12:19 PM
I have Cisco IGESM switches in them. Will it work with these switches?
05-18-2009 12:28 PM
Should be able to. See page 245/550.
