Community Member
ICMP Port Unreachable from gateway 10.x.x.x for udp from testserver (10.x.x.x) to 10.x.x.x port 33440
Sir,
I have attached the output of sun server.what is the reason for
ICMP Port Unreachable from gateway 10.40.20.154
for udp from testserver (10.40.20.13) to 10.20.250.16 port 33440.whetehr it is server problem or switch problem.
testserver # ping -s 10.20.250.16
PING 10.20.250.16: 56 data bytes
64 bytes from 10.20.250.16: icmp_seq=0. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=1. time=40152. ms
64 bytes from 10.20.250.16: icmp_seq=2. time=39152. ms
64 bytes from 10.20.250.16: icmp_seq=3. time=38154. ms
64 bytes from 10.20.250.16: icmp_seq=4. time=37155. ms
64 bytes from 10.20.250.16: icmp_seq=5. time=36156. ms
64 bytes from 10.20.250.16: icmp_seq=6. time=35157. ms
64 bytes from 10.20.250.16: icmp_seq=7. time=34158. ms
ICMP Time exceeded in transit from 10.40.20.122
for udp from testserver (10.40.2013) to 10.20.250.16 port 33437
for udp from testserver (10.40.2013) to 10.20.250.16 port 33438
ICMP Time exceeded in transit from 10.40.20122
for udp from testserver (10.40.2013) to 10.20.250.16 port 33439
for udp from testserver (10.40.2013) to 10.20.250.16 port 33440
64 bytes from 10.20.250.16: icmp_seq=42. time=10036. ms
64 bytes from 10.20.250.16: icmp_seq=43. time=9037. ms
64 bytes from 10.20.250.16: icmp_seq=44. time=8039. ms
64 bytes from 10.20.250.16: icmp_seq=45. time=7040. ms
64 bytes from 10.20.250.16: icmp_seq=46. time=6041. ms
for udp from testserver (10.40.20.13) to 10.20.250.16 port 33442
64 bytes from 10.20.250.16: icmp_seq=47. time=5043. ms
64 bytes from 10.20.250.16: icmp_seq=48. time=4044. ms
64 bytes from 10.20.250.16: icmp_seq=49. time=3045. ms
64 bytes from 10.20.250.16: icmp_seq=53. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=54. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=55. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=56. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=57. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=58. time=0. ms
^C
----10.20.250.16 PING Statistics----
59 packets transmitted, 22 packets received, 62% packet loss
round-trip (ms)  min/avg/max = 0/14200/40152
testserver #
senthil
1 REPLY
Community Member
Re: ICMP Port Unreachable from gateway 10.x.x.x for udp from te
Can you do a packet trace and re-run the ping command?
When you do the packet trace you want to look at the error code.
0 = gateway aka Time-to-live exceeded in transit.
1 = server aka Fragment reassembly time exceeded
That will get you your answer
581
