Webcast-Catalyst9k
ICND1 Glossary
Hi there,
Please I want to know about,
I was looking up in the glossary of ICND1 book. Below p section I found the term (packet) which was defined "
A logical grouping of bytes that includes the network layer header and encapsulated data, but
specifically does not include any headers and trailers below the network layer ", I couldn't understand the 2th part of definition
Everyone's tags (1)
Silver
ICND1 Glossary
It basically means that it does not contain the headers and trailers from the data and physical layer.
See the data link layer adds a frame header and trailer converting the packets into frames, and the MAC sublayer layer converts the frames into a bits which the Physical layer can put on the wire.
Hope this helps.
ICND1 Glossary
Hi Leo,
Do you mean that the signals move across the media called packets rather than bits ?
Thanks in advanced
192
