identify catalyst 6500 chasis
roussillon
I have a Catalyst 6509 but I do not know if it is a Cisco Catalyst 6509-E or Catalyst 6509-NEB or Catalyst 6509-NEB-A or Catalyst 6509-V-E
In the chassis is writen catalyst 6500 Series.
How do I know the chassis model??
I did show ver and it shows
cisco WS-C6509 (R5000) processor (revision 2.0) with 114688K/16384K bytes of memory.
Processor board ID SCA044304FF
How can i know wich model of chassis I have
From the output specified it appears that you have a standard 6509 chassis.
Mark
6 Replies 6
glen.grant
If its a IOS only box do a "show idprom chassis" command.
but the command show idprom chassis does not apply
I found
show idprom:
all selects all FRU-types
backplane specify backplane
clock specify clock
earl specify earl
fan-tray specify fan-tray
interface interface name
module specify module
power-supply specify power-supply
rp specify RP (MSFC)
supervisor specify supervisor
vdb specify vdb
vtt specify VTT
#show idprom backplane
IDPROM for backplane #0
(FRU is 'Catalyst 6500 9-slot backplane')
OEM String = 'Cisco Systems'
Product Number = 'WS-C6509'
Serial Number = 'SCA044304FF'
Manufacturing Assembly Number = '73-3438-03'
Manufacturing Assembly Revision = 'B0'
Hardware Revision = 2.0
Current supplied (+) or consumed (-) = -
So i think is a Catalyst 6509 Switch
Am I rigth?
thanks
Mark Yeates
Level 7
Level 7
On top of Glen's suggestion a "show inventory" will also display the type of chassis.
HTH,
Mark
My bad show idprom chassis is for 4500's , cisco wouldn't want to keep it the same for all models that would make too much sense. Use the show idprom backplane , that is the chassis type you are dealing with .
Product Number = 'WS-C6509-E'
Serial Number = 'XXXXXXXXXXXXX'
Manufacturing Assembly Number = '73-9221-03'
Manufacturing Assembly Revision = 'A0'
Hardware Revision = 1.1
Salut
"show inventory" does not work on my switch
so i did
"show idprom backplane" and this gave:
Mark
