IDSM-2 slot assignment for 6509-E
I'm working in a design of an IDS/IPS Solution and I want to propose an IDSM-2 module for the Catalyst 6509-E Switch located at the Core... The issue is that the only available slot is #6 which is not going to be used by any redundant supervisor... Can you please tell me if I can place the new module there eventough this slot is reserved by default for a redundant Supervisor??
Any help will be deeply appreciated
Thanx
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: IDSM-2 slot assignment for 6509-E
Thanx
You can use slot 6 for any card if you are not using it for a redundant sup.
Jon
Thanx
Jon
Hello Jon,
Thanx for your super quick response... Do you have any available documentation to demonstrate this?? Because I have to do a presentation of my proposal by thursday and I want to be prepared
BR
dsalcedo27 wrote:
Hello Jon,
BR
BR
Not really but i'll have a search. Just know it works from previous experience.
Jon
Silver
As Jon says, you can install an IDSM-2 module in slot 6 of a 6509-E chassis. Slot requirements are typically documented in the hardware installation guides.
"You can install IDSM-2 in any slot that is not used by the supervisor engine."
ref http://www.cisco.com/en/US/docs/security/ips/5.1/installation/guide/hwIDSM2.html#wp712889
Hope this helps,
/Phil
421
