IE 3000
We purchased around 20 IE 3000 switches. Out of 20 we opened 8 boxes and only 3 are working. all others cannot boo from the flash. If we are giving dir command its not showing the flash
Silver
Re: IE 3000
I think it is not possible for all switch but may defect any one. When you first set up the switch, you should use Express Setup to enter the initial IP information. Doing this enables the switch to connect to local routers and the Internet. You can then access the switch through the IP address for additional configuration.
Re: IE 3000
Try these commands assuming that you are at switch: prompt.
flash_init
load_helper
dir flash:
Re: IE 3000
Just remove the flash card on the switch outer body and push it inside again.. Power on the switch,,,
169
