03-07-2007 10:25 PM - edited 03-05-2019 02:46 PM
hello
i am using:
- cisco WS-C3560G-24TS with Version 12.2(25r)SE1
-java2 1.5.0
-ie 7.0
when i try to connect to this switch via web i get this error: The device manager does not support the Internet browser undefined
Click here for more info. Click continue to launch with the unsupported browser
is this a bug? should i upgrade my soft?
Solved! Go to Solution.
03-08-2007 03:52 AM
I use Mozilla FireFox 2, no problem
03-08-2007 01:26 AM
It may not support IE 7 yet , you may have to use IE 6 or I think they support some of the Mozilla browsers .
03-08-2007 02:07 AM
I get this on my CE500 switches, with Opera, and IE7.
If I ignore it, in the case of opera <9 or ie7 it just works as it should.
In the case of opera 9, it keeps refreshing the screen every second or so, making it unusable.
03-08-2007 03:52 AM
