%ILPOWER-5-IEEE_DISCONNECT: Interface Gi0/5: PD removed
Dears
I have a problem with 3560 switch , recently i upgraded the ios to c3560e-universalk9-mz.152-1.E1 , after that i am facing the issue that AP's connected to  this switch get disconnects in every 10-15 mins , i am getting the following logs , AP's are managed by the controller 2504 , and there is no problem with other AP's in the network
Mar 31 01:50:25.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi0/5: PD removed
Mar 31 01:50:25.478: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi0/6: PD removed
Mar 31 02:35:03.004: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi0/5: PD removed
Mar 31 02:35:03.004: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi0/6: PD removed
Mar 31 02:35:03.977: %ILPOWER-7-DETECT: Interface Gi0/5: Power Device detected: IEEE PD
Mar 31 02:35:04.044: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/5, changed state to down
Mar 31 02:35:04.061: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/6, changed state to down
Mar 31 02:35:04.514: %ILPOWER-7-DETECT: Interface Gi0/6: Power Device detected: IEEE PD
Mar 31 02:35:04.564: %ILPOWER-5-POWER_GRANTED: Interface Gi0/5: Power granted
Mar 31 02:35:05.051: %LINK-3-UPDOWN: Interface GigabitEthernet0/5, changed state to down
Mar 31 02:35:05.059: %LINK-3-UPDOWN: Interface GigabitEthernet0/6, changed state to down
Mar 31 02:35:05.076: %ILPOWER-5-POWER_GRANTED: Interface Gi0/6: Power granted
Mar 31 02:35:09.429: %LINK-3-UPDOWN: Interface GigabitEthernet0/5, changed state to up
Mar 31 02:35:09.589: %LINK-3-UPDOWN: Interface GigabitEthernet0/6, changed state to up
Mar 31 02:35:11.443: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/5, changed state to up
Mar 31 02:35:11.610: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/6, changed state to up
it would be grateful if somebody can help me out  in this
Saran
Hall of Fame Super Gold
Non-GigabitEthernet 3560/3750
Non-GigabitEthernet 3560/3750  does not support TDR.
If you have a switch with a GigabitEthernet (copper) then move the connection to that switch for you to do TDR check.
Hi,inline power error
inline power error messages
on a Catalyst 3560. This could be software failure or a potential
hardware failure. to verify , can you  send below outputs:
"show power inline"
 "show version"
Naveen
RW5
I have a 3560 G- Series Cat-6
I have a 3560 G- Series Cat-6  24 port switch witch is rack mounted connected to servers and ASA Firewall.  3560 G- Series maintained all 'green' leds showing connectivity, however, only local connection to the servers NOT the ASA outward bound.  Your answer with POE check "show power inline" seems to be the answer.  Why?  Because, bouncing the switch and the ASA returned the appliances to their original working operational state.  Not only that , the whole data center was being hit by several power hits. At least 9 power hits in the data center withing 8 hour period.
-- i have no access to the administration of the switch or ASA, of which I stated that it was an power error that caused the "break" in the network connection. --Brice
1272
