Webcast-Catalyst9k
increasing DRAM
we hv cisco 2520 router , it uses CPU high upto 100% when load increas , can we add more memory if yes then how much, beside it which router is better then 2500 series.
Re: increasing DRAM
better choice would be the 2800 series router, since the 2500 & 2600 stopped manufacturing, if i am not wrong (2500 is end-of-sale) better optin would be the 2800.
rate this post if helpful
Re: increasing DRAM
I also would suggest to check few parameters like the bandwidth currently being handled by your router and the requirement of ports for your use.
You can refer the attachment for more info..
regds
234
