initial configuration dialog? [yes/no] - how do I get rid of this?
whiteford
I'm setting up a new router and it boots up and says "Would you like to enter the initial configuration dialog? [yes/no]: "
I say no and put the config on and all works well and I type "wr mem".
I turn the router off and back on and I get the "Would you like to enter the initial configuration dialog? [yes/no]: " message again and the config is lost.
I have tried "copy running-config startup-config" and the same thing happens after a reboot.
What simple thing am I missing here?
singhsaju
Level 4
Level 4
Router is bypassing the startup config.
Check config-register value under show version.
You will have to set config register to value 0x2102 .
(config)#config-register 0x2102
Saju
Please rate if it helps.
It says - Configuration register is 0x2142
change it to 0x2102.You should be good then.
Andy
Just to b explicit about the little bit that is implicit in the response from Saju:
- the 4 in 0x2142 indicates that the device should ignore the content of NVRAM during boot (which results in ignore the startup-config at boot time.
- the 0 in 0x2102 indicates that the device should read the content of NVRAM (which is startup-config) at boot time.
The response from Saju is exactly correct and I have rated it as such.
Rick
Rick
