Community Member
Input drops and flushes
We are having a few issues with some of our atm links showing input errors & CRC on one our both of our lightstream 1010's.
Here is an example
ATM3/0/3 is up, line protocol is up
Hardware is oc3suni
MTU 4470 bytes, sub MTU 4470, BW 155520 Kbit, DLY 0 usec, rely 255/255, load 1
/255
Encapsulation ATM, loopback not set, keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w3d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 60000 bits/sec, 147 packets/sec
5 minute output rate 1025000 bits/sec, 2458 packets/sec
125993180 packets input, 2382671244 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1788 input errors, 1954 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
247212253 packets output, 217347521 bytes, 0 underruns
These errors are not showing on the ATM interface of the 7200's on the other end...
Also noticed our GBit interface on our core router had values in the input queue incrementing at a quick rate
GigabitEthernet0/0 is up, line protocol is up
Hardware is i82543 (Livengood), address is 00d0.ffe5.4008 (bia 00d0.ffe5.4008)
Internet address is 10.200.2.254/24
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex mode, link type is autonegotiation, media type is SX
output flow-control is off, input flow-control is off
Last clearing of "show interface" counters 01:56:21
Input queue: 1/75/118/6809 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/40 (size/max)
5 minute input rate 10946000 bits/sec, 2074 packets/sec
5 minute output rate 4530000 bits/sec, 1694 packets/sec
15121726 packets input, 2118492864 bytes, 0 no buffer
Received 88626 broadcasts, 0 runts, 0 giants, 91 throttles
0 watchdog, 0 multicast, 0 pause input
12417049 packets output, 305509368 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Not sure if these are connected, any help would be appreciated.
128
