Community Member
Input Drops on TenGigabitEthernet Links
I'm seeing input drops/flushes on a group of 10GB interfaces.
Utilization is around 1%, so utilization is not an issue.
What else should I be looking at to determine the root cause?
Thanks-
Blue
Re: Input Drops on TenGigabitEthernet Links
Hi:
Just do the obvious first...
Check the fiber cables -- swap them out if you have to
Swap out the GBICs too
Make sure your speed and duplex settings are correct.
You know...basic layer 1 stuff.
VL
Hall of Fame Super Silver
Hello Joseph,
have a look at the following it describes some bugs that might apply to your case
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml#subtopic3d
meaning of input drops:
Input queue - The number of packets in the input queue. Size/max/drops means the current number of frames in the queue/the max number of frames the queue can hold before it must start dropping frames/the actual number of frames dropped because the max queue size was exceeded. The input queue size can be modified by issuing the hold-queue in interface command. Be careful when increasing the size of the queue as this may result in traffic delays because the frames get stuck in the queue for a longer period of time.
from
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a0080118a5c.shtml#step12
Hope to help
Giuseppe
Community Member
Also, make sure you are using 10Gig certified cabling. It should be aqua in color. If you are using standard 1 gig cable (yellow or orange in color) they may not be up to the task.
Community Member
Thanks to all for your observations and suggestions. They will help me formulate a strategy to address this issue.
262
