Bronze
Input errors 6509
We have recently set up a 6509, experiencing errors on both of the
WS-X6748-GE-TX modules. Its on the trunk interfaces to 2 cisco WS-C3550-24.
When we moved the trunk to the sup port
we got no errors.
We are planning to connect a pc to the ports to see if the problem persist.
Any ideas ?
#sh int GigabitEthernet1/3
GigabitEthernet1/3 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is 001a.a249.8aaa (bia 001a.a249.8aaa)
MTU 1546 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input 1d03h, output 1d03h, output hang never
Input queue: 0/2000/100455/0 (size/max/drops/flushes); Total output drops: 1
Queueing strategy: fifo
Output queue: 0/40 (size/max)
43209443 packets input, 51556057716 bytes, 0 no buffer
Received 9745 broadcasts (9148 multicast)
100455 input errors, 0 CRC, 0 frame, 64 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
43208415 packets output, 51699821574 bytes, 0 underruns
1 output errors, 0 collisions, 2 interface resets
Bjornarsb
1 REPLY
Anonymous
N/A
Re: Input errors 6509
If you ever see hits on the "Input queue" in 'sh int',it means you are process switching traffic which is ,really bad. show cdp traffic CDP counters will be helpful command.
For more information please click following URL:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a0080118a5c.shtml
546
