inside interfaces only participate in EIGRP
kamal gargoum
i enabled EIGRP in 2911 router only the lan interfaces which has the ip nat inside enabled is showing in show ip eigrp interface:
st    Pending
Interface              Peers  Un/Reliable  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Gi0/0.116                0        0/0       0/0           0       0/0            0           0
Gi0/0.115                0        0/0       0/0           0       0/0            0           0
NV0                      0        0/0       0/0           0      11/11           0
it dosent sow the other interfaces , i think the problem from the NV0 interfce (the virtual nat interface), which is take the the same IP as the internal interface 0/0.115:
GigabitEthernet0/0.115     192.168.15.2
NVI0                               192.168.15.2
i traied to remove the NVI0 int by deleting nat enabler from the interfaces no ip nat enable and use the old nat ip nat inside/outside in the interfaces.
but i still see the NVI0 up and it still has the samip as the internal interface.
i even tried ospf and other routing protocols but it is still the sam problem only the internal interfaces are forwording the routing messages
You have this for your EIGRP config -
router eigrp 1
network 10.10.16.0 0.0.0.255
network 192.168.15.0
the interfaces with "ip nat outside" are using 172.21.x.x addressing, If you want them to participate in EIGRP you need to add network statements for them under your EIGRP config.
Jon
12 Replies 12
John Blakley
Do you have acls applied to any of the interfaces? If so, be sure to allow eigrp through. If not, I can lab this up today to see if I get the same problem.
Hth,
John
HTH, John *** Please rate all useful posts ***
no there is no acls applied now
i remove them after i faced this problem and still no other interfaces apears
i just want to know why the NVI0 have an IP and how i can remove it , because i strongly thing that the problem from it
thank you
NVI interface shouldn't have any effect on EIGRP interfaces and I labbed it up to confirm with a 12.4(15)T7 image.
I don't think you can get rid of the NVI interface which is only used if you use NAT NVI instead of legacy NAT but appears even if you configure legacy NAT.
Can you post your config and topology.
Alain
Hello
Domain NAT - ip nat inside/outside
Domainless NAT- ip nat enable -NVI interface is utilized
Nat NVI is used in domainless natting -  that is applying nat without the inside/outside nat commands
It also performs differently in the lookup procedure than domain Nat
Domain NAT has difeerent orders of operation= http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Inside Nat looks in the ip routing table prior to nat translation
Outside nat - translates before lookup ip route table
Domainless NAT performs two lookups:
Once in the NVI interface and then in the ip routing table
http://blog.ine.com/2008/02/15/the-inside-and-outside-of-nat/
Lastly the NVI interface can be removed if you reload your router.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
but this is dose not explain why the NVI0 interface has an IP address
it shouldn't has any IP int normal state :
Ben-GW#sh ip int br
GigabitEthernet0/0.115     192.168.15.2    YES NVRAM  up                    up
NVI0                                192.168.15.2    YES unset  up                    up
Hello
When enabling nat on a active interface, the NVI interface will take the ip address of the first interface you enable nat on.
Saying that only Domianless nat( NVI NAT) utilises this interface, Domain NAT ( legacy nat)  uses a different NAT Order as previously stated.
Res
Paul
Thanks.
Kind Regards
Paul
but why the NVI0 intrface has an IP of the internal interface.
ok this is my configurations:
version 15.2
service password-encryption
hostname Ben-GW
boot-start-marker
boot-end-marker
logging buffered 52000
no logging console
aaa new-model
aaa authentication login default local
aaa authentication login userauthen local
aaa authorization network groupauthor local
no ip domain lookup
ip domain name aljeel.ly
ip cef
no ipv6 cef
voice-card 0
ip ssh authentication-retries 4
class-map match-any BAD-P2P
match protocol bittorrent
match protocol edonkey
match protocol gnutella
match protocol kazaa2
match protocol fasttrack
match protocol winmx
policy-map police
class BAD-P2P
  drop
class class-default
  police 20000000 conform-action transmit  exceed-action drop  violate-action drop
interface Loopback1
ip address x.x.x.x. 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly in max-fragments 64 max-reassemblies 1024
no ip route-cache
interface Tunnel4
ip address 172.28.9.2 255.255.255.252
ip mtu 1476
tunnel source 172.30.1.26
tunnel destination 172.30.1.13
interface Tunnel11
ip address 172.28.11.2 255.255.255.252
tunnel destination 172.30.1.3
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.115
encapsulation dot1Q 115
ip address 192.168.15.2 255.255.255.0
ip nbar protocol-discovery
ip nat inside
ip tcp adjust-mss 1452
interface GigabitEthernet0/0.116
encapsulation dot1Q 116
ip address 10.10.16.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.750
encapsulation dot1Q 750
ip address 172.21.2.100 255.255.255.0
ip nat outside
ip virtual-reassembly in max-reassemblies 1024
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1.751
encapsulation dot1Q 751
ip address 172.21.3.60 255.255.255.0
ip nat outside
interface GigabitEthernet0/1.900
encapsulation dot1Q 900
ip address 172.30.1.26 255.255.255.248
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
duplex auto
speed auto
interface SM1/0
no ip address
shutdown
!Application: CUE Running on SM
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
interface Dialer1
ip unnumbered Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
ppp authentication chap callin
ppp chap hostname BG-ALJEEL-OFFICE
ppp chap password 7 0026344B257721232A0D01612F3F2C3437
ppp ipcp route default
ppp ipcp address accept
no cdp enable
router eigrp 1
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no ip address
duplex auto
speed auto
ip nat outside
ip nat outside
no ip address
duplex auto
speed auto
interface SM1/0
no ip address
shutdown
interface SM1/1
no ip address
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
no cdp enable
router eigrp 1
no ip http server
this is all of the configurations
regards
As Paul explained the NAT NVI is created when you first enable NAT on an interface so it means you first did ip nat inside then ip nat outside so NVI was initialized with ip nat inside and took the IP address oif the nat inside interface.
Alain
so my problem with the eigrp itselve not with NVI0 interface.
i tried to point to the neighbor router in eigrp but it still not working the neighbor router still doesn’t receive any messages from the interface which they connected to.
regards
You said that  sh ip eigrp interface output doesn't include your nat outside interface? Is this correct?
Can you post sh ip int   for the  nat outside interface  and sh run | s r ei
Alain
router eigrp 1
Jon
thank you it worked !!
when i addwd the network of the outside interface it starts to send messages to neighbor router
but i just want to advertise the internal network in the other routers how i can do that ?
thank you again
