Install and run SDM on External Flash?
I have a CCME router who's files take up pretty much the entire internal flash. I would like to install SDM and run it from the external USB flash, but I have no idea what files need to be on there. Also, once they are on there, how does the router recognize running the SDM from the USB flash?
Ed
1 REPLY
Silver
Re: Install and run SDM on External Flash?
This window tells you if SDM has detected a USB token or USB flash device connected to your router. You can click the Router Provisioning button to choose a configuration file from the USB token or USB flash device.
If you choose to provision your router this way, the configuration file from the USB token or USB flash device is merged with your router's running configuration file to create a new running configuration file.
This window allows you to load a configuration file from a USB token or USB flash device connected to your router. The file will be merged with your router's running configuration file to create a new running configuration file.
To load a configuration file, follow these steps:
Step 1 Choose the device type from the drop-down menu.
Step 2 Enter the configuration file name in Filename, including the full path, or click
Browse and choose the file from the File Selection window.
Step 3 If the device type is a USB token, enter the password to log in to the token in
Token PIN.
Step 4 If you want to preview the file, click Preview File to display the contents of the
file in the details pane
Step 5 Click OK to load the chosen file
For further information clickthis link.
http://www.cisco.com/univercd/cc/td/doc/product/software/sdm/22ug/sdmh22.pdf
182
