Community Member
Installing an SFP 1000Base-T into a 3750?
I have just recieved a SPF to install into my C3750 switch to provide me with a gigabit trunk to a C2960.
DO I just push the SPF in and that is it? The switch is on and live, so I'm not sure if I have to down this switch first?
1 REPLY
Bronze
Re: Installing an SFP 1000Base-T into a 3750?
SFP's are hot-swoppable - so you can insert or remove them while the switch is on.
All you need to do is push it in and plug the ethernet cable.
294
