Int f0/0 and f0/1 networks cannot communicate. reason?
harris_732
I have tow networks on my two router interfaces i.e on f0/0 and f0/1. I can ping from pc to the other network pc but canot ping the other network switch nor both switches can ping eachother. I cannot understand why. plz help.
7 Replies 7
John Blakley
Do you have any acls or firewalls in between the two networks?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Can you post the configuration of both interfaces? Also if these are windows machines, is it possibe to turn the firewall off and test again?
No, I don't have any acls or firewalls in between the two networks.
prajithtr_2
Does the manage IPs of switches adverise properly in the router and could you check the default gateway in the switches configured properly..
Kindly post the configurations
Yes I have checked and the default gateway was not configured on the switches. now its working . Thanks Alot to everybody here who responded to my query.
The IP's are in the same network? The gateway's are of both switches are configure correctly?
Yes the gateway was not configured, now its working. Thanks alot
