Intel Pro 100 & Cisco Catalyst 2960G
Hello, I have this issue:
Switch Cisco Catalyst 2960G + utp cat 6 cable + nic Intel Pro 100 VM (With WIN XP latest drivers)
I can't get it work.
Autosensing in both points = cable disconected
100 full in both points = connection ok, but no pings
100 half in both pints = connection ok, but no pings
10 full or half in both points = lose many pings (50% of them)
This problem happens only with this type of nic (tested three different ones). If I change the nic (intel pro 1000, 3com, or realteck, or Broadcom) the connection is ok at any speed (10 / 100 / 1000).
Is there any know bug or problem related with this nic?
NOTE: unchecking "allow the computer turn off this device" doesn't work.
1 REPLY
Re: Intel Pro 100 & Cisco Catalyst 2960G
Issue seems to be with the Intel drivers.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note0918
6a00800a7af0.shtml#nic_comp
I would suggest you contacting Intel and see if they have a fix for the
drivers.
NT
564
