09-08-2013 11:38 AM - edited 03-07-2019 03:21 PM
I have set a VLAN network.I am able to ping members of same VLAN domain but inter-vlan pinging is not getting any suiccess.I am using router for this purpose.Here is the packet-tracer file.Please help me out.
http://www.mediafire.com/download/50s1emfxqbl2g3e/vlan.pkt
thank u
Posted by WebUser Anik Biswas from Cisco Support Community App
Solved! Go to Solution.
09-08-2013 12:19 PM
Hello Web User
1. your IP scheme is incorrect
meaning ur routable interfaces no the RT have subnet /24 but ur subnets on a computers are /16 instead of /24
2. IP address on vlan interface on the router on the stick is incorrect
meaning vlan 2 shoud have ip 172.16.2.1 (regarding on ur topology) but in real it has 172.16.3.1 so
here is ur problem u have computer that coccected to the vlan 2 and have ip 172.16.2.3 DG 172.16.2.1 when ur DG (aka fa 0/1.2 encaps dot1q 2) has ip address 172.16.3.1
P.S. in my opinion the network will not perform really good because if u want to use around 4 vlans i will sugest to go with L3 switch and do inter-vlan routing on the L3
Hope this was helpfull
09-08-2013 12:19 PM
Hello Web User
09-08-2013 09:17 PM
As per ur suggestion I have changed the subnet of the hosts and matched with the router.But still the inter-vlan ping is not successful. Here is the new file
Please help
09-08-2013 09:51 PM
Thank u for ur help.After changing the encapsulation it worked..
