Webcast-Catalyst9k
Inter VLAN communication
1) I have created 4 VLANs as 10,20,30,99. (VLAN 99 is used for Management&Native)
2) used one VTP server & 3 VTP client modes. and each VLAN independandly communicating well.
3) And created 3 subinterfaces in a router for 3 VLANS ( encapsulation dot1Q 10, encapsulation dot1Q 20, encapsulation dot1Q 30)
Here my quistion is that:-
1) Without any routing protocol will it happen Inter VLAN communication....?
2) Is there need to create Subinterface for VLAN 99 (for Management&Native)
        -Siyadh.
Re: Inter VLAN communication
You would only be able to communicate with hosts in the same vlan, but intervlan communication would break.
Hosts in vlan 10 ---> 10 will work
Hosts in vlan 10 ---> 20 or 30 will not
No need to create one, but it takes the primary address on your interface:
int fa0/0 (vlan 99 = untagged)
ip address 192.168.0.1 255.255.255.0
int fa0/0.20
encaps dot1q 20
ip address 192.168.20.1 255.255.255.0
int fa0/0.30
encaps dot1q 30
It wouldn't hurt anything if you wanted to change your fa0/0 to encapsulate 99 if you wanted:
int fa0/0
encaps dot1q 99 native
HTH,
John
HTH, John *** Please rate all useful posts ***
Thank you John,
this is my routing table
C    172.10.0.0/16 is directly connected, FastEthernet0/0.1
C    172.20.0.0/16 is directly connected, FastEthernet0/0.2
C    172.30.0.0/16 is directly connected, FastEthernet0/0.3
And i did not configure any routing protocols.
But i am getting Inter VLAN communication(  vlan 10 ---> 10 or 20 or 30).
IP address of PC which is in VLAN 10
          PC>ipconfig
          IP Address......................: 172.10.0.13
          Subnet Mask.....................: 255.255.0.0
          Default Gateway.................: 172.10.0.1
Successfull ping from    172.10.0.13  (VLAN 10) to 172.20.0.13 (VLAN 20)
     PC>ping 172.20.0.13
     Pinging 172.20.0.13 with 32 bytes of data:
     Reply from 172.20.0.13: bytes=32 time=111ms TTL=127
     Reply from 172.20.0.13: bytes=32 time=140ms TTL=127
So i concluded without any routing protocol Inter VLAN communication will happen by subinterface.
        - Siyadh.
I completely misread your question. I thought you were asking if you weren't configuring routing for vlans. You're correct. You don't need a routing protocol (eigrp/bgp/ospf) in order to pass traffic. Sorry for my misreading....
728
