01-06-2014 02:41 PM - edited 03-07-2019 05:24 PM
Hi to all,
I am currently trying to reach a printer on another network using a Layer 3 switch (Cisco 3750)
Here is a simplified diagram :
WIFI ROUTER ------------------- CISCO 3750
(10.1.100.1) VLAN 1 (10.1.100.4) -------------------- Business network (10.1.100.xx)
VLAN 20 (192.168.2.92) --------------- Second network (192.168.2.xxx)
I am trying to reach a printer at address 192.168.2.50
From the 3750 CLI, I can successfully ping 192.168.2.92 and 192.168.2.50
After setting up a static route in the Wifi router (192.168.2.0 255.255.255.0 10.1.100.4), I can ping 192.168.2.92
The router is a Asus RT-N66U with default gateway at 10.1.100.1
I still cannot find a way to reach 192.168.2.50
Could someone help me ?
Thanks & regards,
*********************************************** CISCO 3750 config ************************************************
Switch4#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.1.100.1 to network 0.0.0.0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.100.0 is directly connected, Vlan1
C 192.168.2.0/24 is directly connected, Vlan20
S* 0.0.0.0/0 [1/0] via 10.1.100.1
Switch4#sh vlan
VLAN Name Status Ports
1 default active Fa1/0/1, Fa1/0/2, Fa1/0/3
Fa1/0/4, Fa1/0/5, Fa1/0/6
Fa1/0/7, Fa1/0/8, Fa1/0/9
Fa1/0/10, Fa1/0/11, Fa1/0/12
Fa1/0/13, Fa1/0/14, Fa1/0/15
Fa1/0/16, Fa1/0/17, Fa1/0/18
Fa1/0/19, Fa1/0/20, Fa1/0/21
Fa1/0/22, Fa1/0/23, Fa1/0/24
Fa1/0/25, Fa1/0/26, Fa1/0/27
Fa1/0/28, Fa1/0/29, Fa1/0/30
Fa1/0/31, Fa1/0/32, Fa1/0/33
Fa1/0/34, Fa1/0/35, Fa1/0/36
Fa1/0/37, Fa1/0/38, Fa1/0/39
Fa1/0/40, Fa1/0/41, Fa1/0/42
Fa1/0/43, Fa1/0/44, Fa1/0/45
Fa1/0/47, Fa1/0/48, Gi1/0/1
Gi1/0/2, Gi1/0/3, Gi1/0/4
20 VLAN0020 active Fa1/0/46
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
--More--
Switch4#sh int vlan 1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 001b.90a9.6640 (bia 001b.90a9.6640)
Internet address is 10.1.100.4/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 3 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
406783 packets input, 29302594 bytes, 0 no buffer
Received 0 broadcasts (1255 IP multicasts)
23639 packets output, 1948644 bytes, 0 underruns
0 output errors, 2 interface resets
Switch4#sh int vlan 20
Vlan20 is up, line protocol is up
Hardware is EtherSVI, address is 001b.90a9.6641 (bia 001b.90a9.6641)
Internet address is 192.168.2.92/24
Last input 00:00:00, output 00:00:01, output hang never
5 minute input rate 1000 bits/sec, 1 packets/sec
147138 packets input, 10454310 bytes, 0 no buffer
Received 0 broadcasts (561 IP multicasts)
5391 packets output, 392013 bytes, 0 underruns
0 output errors, 1 interface resets
01-07-2014 08:38 PM
Can you check the default gateway on your printer ?
Even if the default gateway is not configured on the printer, this communication will be possible. Because both ends are in the same network: 192.168.2.0.
But in the other case from the printer's end the destination will be:10.1.100.0/24. If the default gateway is not configured on the printer, it would probably don't know where to send the packets ?
If possible, can you please also post a traceroute from the device you are trying to speak to printer?
Rate if it is helpful.
Chandu
01-08-2014 03:54 AM
You are correct, When pinging with a source address of 10.1.100.4 I did not get a reply.
Since I am not the manager of the printer and cannot change the gateway to 192.168.2.92, I asked to add a static route in the other network router :
10.1.100.0 255.255.255.0 192.168.2.92
At this time I was able to ping but cannot print at all.
Then I asked for port 9100 to be un locked.
Now I can start a print job but it stops halfway, gives an error and the job restart, stop halfway, restart ... on and on
Any ideas ?
01-08-2014 04:00 AM
Thanks for the feedback. Please rate my previous post.
And regarding the print job, are you seeing any packet loss while pinging the printer from your device ?
If possible check if this is happening if you're printing from the local device instead from the remote device.
Chandu
01-08-2014 04:04 AM
You are correct .. when pinging in windows from a 10.1.100.xx client with command :
ping 192.168.2.50 -t
I don't get a ping response about 1 time in 25 requests
Printing from the local device works fine.
What could be the cause of this ?
01-08-2014 04:11 AM
That 1time "Request failed" will be probably for an ARP. So that is not a problem.
Usually in my LAN whenever i get these type of issues, it would be probably related to only one PC. Printing from other PC would be fine most of the time.
I used to shutdown the PC & Printer for few mins & Power up then the issue used to solved.
Chandu
01-08-2014 04:25 AM
I tried with another PC on the network already and had the same problem
01-08-2014 04:36 AM
Correlate the printing preferences and printer settings on both the local device and the remote device.
Give a try.
Chandu
01-08-2014 05:31 AM
I used the same computer on both network so configuration is not a problem
01-08-2014 11:09 AM
EDIT : Thinking about it, I asked the IT guy to make the route but did not specify a metric value. Could that be the problem if the metric is only set to 1 ? Also, on the tracert that does not work, I cannot ping 10.1.100.10 neither.
Another weird thing :
When connected to 192.168.2.xx network
>tracert -d 10.1.100.1
Tracing route to 10.1.100.1 over a maximum of 30 hops
1 1 ms 1 ms 1 ms 192.168.2.1
2 7 ms 2 ms 3 ms 192.168.2.92
3 1 ms 1 ms 1 ms 10.1.100.1
Trace complete.
>tracert -d 10.1.100.10
Tracing route to 10.1.100.10 over a maximum of 30 hops
2 7 ms 3 ms 3 ms 192.168.2.92
3 *
When connected to 10.1.100.xx network
>tracert -d 192.168.2.1
Tracing route to 192.168.2.1 over a maximum of 30 hops
1 1 ms 1 ms 5 ms 10.1.100.1
2 3 ms 1 ms 1 ms 10.1.100.4
3 1 ms 2 ms 7 ms 192.168.2.1
Trace complete.
>tracert -d 192.168.2.50
Tracing route to 192.168.2.50 over a maximum of 30 hops
1 1 ms <1 ms <1 ms 10.1.100.1
3 1 ms 1 ms 1 ms 192.168.2.50
Trace complete.
