10-16-2006 12:58 PM - edited 03-05-2019 12:16 PM
whitout intervlan routing, how can i link 2 or more vlan at layer 2?
regards.
10-16-2006 01:15 PM
Whenever hosts in one VLAN need to communicate with hosts in another VLAN, the traffic must be routed between them. This is known as inter-VLAN routing. On Catalyst switches it is accomplished by creating Layer 3 interfaces (Switch virtual interfaces (SVI) ).
To have a communication between 2 vlans in a layer 2 switch The ip default-gateway command is used to specify the default gateway when routing is not enabled. But the layer 2 switch should be connected to a layer 3 device which will be doing routing on behalf of this device.
Dude if you can explain your requirement in detail probably I can help
10-16-2006 01:34 PM
Inter-vlan bridging can bridge multiple VLANs simultaneously at layer 2. There are some downsides to enabling vlan bridge. See the below document for more info.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800a7af6.shtml
Sundar
10-17-2006 01:20 AM
i 'll take an example.
switch A has 2 interfaces : f0/1 and f0/2.
f0/1
switch port access vlan 2
f0/2
switch port access vlan 3
2 device are connected on f0/1 and f0/2, the 2 device are on the same subnet: 10.1.1.x/24
how can i do to permi the 2 devices to communicate directly without ip routing ?
Regards.
10-17-2006 01:34 AM
Hi Friend,
If you do not want ip routing to be enabled than there is a workaround for that and what you can do is configure another 2 interface again with vlan 2 and vlan 3 and connect those two interface with a cross cable and your machines in 2 different vlan can communicate then.
Ankur
10-17-2006 06:33 AM
thanks,
How can i do it by soft ?
Regards.
10-17-2006 03:49 AM
I believe as explained earlier you can do this by brigding between the 2 vlans.
Check the following link:
Vlad
