Inter-vlan ping to AP - AP does not respond from vlan 1!
rodolfogallego
Hi all,
I am experiencing a very odd issue.
I have a switch 3550 with a very basic setup.
2 Vlans, one for data and another for Wireless
Vlan 1 is 192.168.1.x
vlan 30 is 192.168.30.x
I have assigned each Vlan 16 ports
I can ping back and forth devices on each vlan which means ip routing is working as expected.
A PC on VLAN 1 can ping a PC on VLAN30 and vice versa.
My access point is 192.168.30.210. I can manage the device and ping it from VLAN 30 but not from VLAN 1. The problem only happens with APs.
I have used a 3com and a netgear.. no joy...does not reply.
If i ping from the 192.168.30.x network it responds but not from the 192.168.1.x
ahh.. another oddity... i can ping the AP from the 3550!
The APs have the VLAN 1 ip as the gateway
Any ideas?
core#ping 192.168.30.210
Sending 5, 100-byte ICMP Echos to 192.168.30.210, timeout is 2 seconds:
core#sh run
Building configuration...
Current configuration : 4300 bytes
version 12.2
no service pad
hostname core
no aaa new-model
ip subnet-zero
ip routing
vtp domain SWLAB
vtp mode transparent
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 30
name WLAN
interface FastEthernet0/1
switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 30
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
13 Replies 13
Reza Sharifi
The ip default-gateway command should only be used when routing is disable on the switch..
so, can you remove ip default-gateway 192.168.1.1 from your config and test again?
Hi Reza,
Thanks for looking into this.
I have followed your suggestion but it doesnt work... still does not reply to pings from a machine on VLAN 1.
However, I can connect to the Access point and can ping the server (on vlan 1) and all the other stuff.
I really dont understand Why it replies to a ping if I have a 192.168.30.x address but not to a 192.168.1.x address
I i plug a computer to the vlan 30 it will reply to pings from a 192.168.1.x... its just the AP that does not reply. Weird..
What I did was to setup a Windows server qith DHP role on 192.168.1.160 with 2 scopes. one for the wireless (192.168.30.x) and another for the LAN 192.168.1.x
With the ip helper address 192.168.1.160 with worlks perfectly...
Devices connects to the AP willl get and ip of 192.168.30.x and can access the server happilly on 192.168.1.160
Devices connected to LAN get IPs of 192.168.1.x
How odd is this?
Thanks!
What port from your the switch is connected to the AP?  Can you make that port a trunk port on both the switch and AP and test again?
Is "IP routing" enabled on on the switch?
Hi rodolfo,
this is not inter-vlan routing. Until you do not start a routing process and advertise the vlan subnets below this process you will not be able to ping an AP from Vlan 1 to an AP in Vlan 30.
conf t
ip routing
router ospf 1
network 192.168.1.0 0.0.0.255 area X
network 192.168.30.0 0.0.0.255 area X
log
a process similar to this is telling to Vlan 30 that at Layer 3 there is Vlan 1 to speak with. Inter-Vlan routing is involving layer 3 decisions despite the confusing name.
One thing more. For your verification use
ping 1.1.1.1 source 2.2.2.2
it is helpful to understand which network is properly advertised on the current routing table.
Alessio
Alessio,
There is only one switch and the subnets/vlans are connected interfaces, therefore there is no need to run a routing protocol.
Hi Reza,
to let two different vlans speak you need a layer 3 decision. Now, my partial config was just an example of a layer 3 decision but whatever you implement you need a layer 3 point which will put in contact the two different broadcast domains.
this if you want to do INTER-vlan routing. Maybe i misundertood your goal.
actually a classical config would be:
interface g0/1
encapsulation dot1q
switchport mode trunk
switchpor vlan allowed 1,30
on the switch
and
int g0/1
no shut
interface g0/1.1
encapsulation dot1q 1
interface g0/1.30
encapsulation dot1q 30
!whatever routing process required for these two subnets.
on the router. On the router (Layer 3 point) these vlans would be able to speak each other.
Alessio
The APs have the VLAN 1 ip as the gateway????????
Make Vlan30's IP address the DG. Moreover, for some APs. a trunk interface is created between the switch and the AP. An IP add is assigned to the BVI interface and this IP address belong to the subnet of native vlan.
Alessio,
As Reza mentioned, all you need is "ip routing" statement on the L3 switch and it will take care of all routing in this case. Even in your case, you don't need any specific routing protocol to route packets within the same box, router knows how to route packets for two connected interfaces.
Hi guys,
here the command:
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdipadr.html#wp1020435
This command is only enabling IP routing. It does not route anything itself.
Infact, issuing no ip routing is a very useful command to work with a layer 2 only switch
Alessio
Please read this too:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Alessio
Can u make switchport mode access and try..... since u enabled ip routing this should work when it is within the switch.....
Hi, I will try to make the AP access port a trunk, but wouldn't that be a security concern? And once I make it a trunk port will it assign a 192.168.30.x address?
Thanks!
Test
As previous poster said if the ap's are in vlan 30 then the gateway must be the vlan 30 SVI address on the 3550  to get off its own subnet.
