09-07-2009 08:30 PM - edited 03-06-2019 07:37 AM
I need pointers in using one of my Cisco router as an inter VLAN router routing between VLAN's on HP Procurve Switch. Any documentation would really help
09-07-2009 08:32 PM
Which router model ?
09-07-2009 08:37 PM
1760 is the current router employed at the remote site but i got a spare 1841 and a 2600
09-07-2009 08:47 PM
Okay, you can use routing-on-a-stick. Basically you configure the port on the Procurve that the router connects to as a trunk and then you configure the subinterfaces for the vlans on the router.
Have a look at this link which gives you a basic config to get you started -
http://www.tech-recipes.com/rx/1853/Cisco_switch_802_1q_trunk_to_router_on_a_stick/
Jon
09-08-2009 12:44 PM
Thanks for your reply. Link helps. Do you have any cisco documentation on inter vlan routing between Cisco and other brand switch - in my case Cisco and HP Procurve switches
11-11-2009 03:22 PM
Finally figure this out. On the HP switch port where the router is connected I have to untagged the management VLAN and tagged the other VLAN's.
Thank you all
11-11-2009 03:28 PM
For those who works with cisco and HP this is how I did it:
Here is what I did it:
Cisco Router
interface FastEthernet0/0
description MMGNT
ip address 192.168.11.1 255.255.255.0
ip helper-address 192.168.10.3
ip nbar protocol-discovery
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/0.1
description SRV-PRT-CLNT
encapsulation dot1Q 2
ip address 192.168.10.253 255.255.255.0
interface FastEthernet0/0.2
description VoIP
encapsulation dot1Q 3
ip address 192.168.62.1 255.255.255.0
HP 2510 Switch
Running configuration:
; J9019A Configuration Editor; Created on release #Q.11.07
hostname "CETC-OFFICE"
interface 25
speed-duplex 1000-full
exit
ip default-gateway 192.168.11.1
snmp-server community "public" Unrestricted
vlan 1
name "MMGNT"
untagged 24
ip address 192.168.11.3 255.255.255.0
tagged 25-26
no untagged 1-23
exit
vlan 2
name "SRV-PRT-CLNT"
untagged 1-23
no ip address
tagged 24-26
exit
vlan 3
name "VoIP"
no ip address
tagged 24-26
voice
exit
management-vlan 1
