Inter-Vlan Routing and No Internet Access-3550 to an ASA 5505
     I have setup a Cisco 3550 with EMI to do Inter-Vlan routing and that is working fine however I cannot access the internet.
- I have configured the 3550 with a default route to the 5505's internal interface.
- Configured a name-server on the 3550 to resolve DNS queries.
On the 5505 I configured a static route back to the IP addresses of the VLANS located on the 3550.
Syslog error when I try to access the internet- Deny inbound UDP from x.x.x.x/53 to y.y.y.y./50561 due to DNS response.
Thanks in advance...
Re: Inter-Vlan Routing and No Internet Access-3550 to an ASA 550
There's a DNS response being blocked on the ASA?
The DNS server that you're using is local or is an external DNS server?
Can you get out to the Internet using IP addresses instead than DNS names?
For example, do you get the cisco homepage when doing:  http://198.133.219.25/
Federico.
I tried with the Cisco IP and no dice, I tried that earlier with Yahoo's IP... Thanks
Ok,
From the ASA, you have Internet access? (can you PING 4.2.2.2 from the ASA)?
If you enable ICMP inspection on the ASA, you should be able to PING 4.2.2.2 or any public Internet IP from the inside LAN (or VLANs).
To enable ICMP inspection, you do:
policy-map global_policy
class inspection_default
  inspect icmp
I'm just trying to find out if the problem is with connectivity to the Internet or just a DNS issue.
Federico.
I added the ICMP inspection rule and tried to ping 4.2.2.2 and did not get a response.
Here are the configs;
ASA Version 8.2(2)
hostname ciscoasa
enable password TGFUt.AsMHJOyury encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.12.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
access-list 100 extended permit tcp any interface outside eq ftp
access-list 100 extended permit tcp any interface outside eq ftp-data
access-list inside_access_in extended permit ip host 172.16.0.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface ftp 172.16.13.2 ftp netmask 255.255.255.255
static (inside,outside) tcp interface ftp-data 172.16.13.2 ftp-data netmask 255.255.255.255
access-group 100 in interface outside
route inside 172.16.0.0 255.255.0.0 172.16.12.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 172.16.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:96ac4d497a990d9241cd20a5db53642c
: end
3550 Config
Building configuration...
Current configuration : 2436 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
no switchport
ip address 172.16.12.2 255.255.255.0
interface FastEthernet0/2
description Server VLAN2
switchport mode access
interface FastEthernet0/3
description User VLAN3
switchport access vlan 3
interface FastEthernet0/4
switchport mode dynamic desirable
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan2
description SERVER_VLAN
ip address 172.16.13.1 255.255.255.0
interface Vlan3
description USER_VLAN
ip address 172.16.14.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.12.1
ip http server
control-plane
line con 0
speed 57600
line vty 0 4
login
line vty 5 15
login
end
Running out for a few, will continue when I get back. Thanks for your help...
There's no default gateway showing in the configuration from the ASA, I think that is because
you're getting it via DHCP.
Can you confirm two things from the ASA...
1. ping 4.2.2.2  --> make sure its succesful
2. sh route --> shows a default gateway
Please verify the above.
Federico.
I still can't ping 4.2.2.2. This is the return error message from  4.2.2.2, I am fine going out.
6May 31 201008:47:523020214.2.2.20x.x.x.x10136Teardown ICMP connection for faddr 4.2.2.2/0 gaddr x.x.x.x/10136 laddr x.x.x.x/10136
Show Route
Gateway of last resort is x.x.x.x to network 0.0.0.0
C    172.16.12.0 255.255.255.0 is directly connected, inside
S    172.16.0.0 255.255.0.0 [1/0] via 172.16.12.1, inside
C    x.x.x.x x.x.x.x is directly connected, outside
d*   0.0.0.0 0.0.0.0 [1/0] via x.x.x.x, outside
Running out now, be back in a couple hours....
1196
