08-28-2016 05:54 AM - edited 03-08-2019 07:11 AM
Actually we are an ISP & we are providing broadband & lease line connection at various location. We have some remote sites, for those sites we have point to multipoint connection. These point to multipoint connection provided by many big ISP's. In our NOC we have separate mux for every ISP. Every remote sites identified with a particular vlan. So every ISP give us a trunk port for those vlans. Now we put the trunk link comes from MUX to a distribution L2 switch & after that we assign another trunk port for those vlan & put the link to CISCO-3650 where all the SVI's for vlan are configured. Now the issue is we can't ping to the remote host from CISCO-3650. I have checked the mac address on my CISCO-3650 & as usual i get the mac of the remote host. I have also checked the mac at the distribution L2 switch also & as usual I get both SVI interface & remote host mac.
We have configured the same in cisco-3550 & it's working like a charm. We have cisco-3750 also & we have tried the same thing on this switch also but the issue remain same.
Can any one tell why this issue is happening in particular series of cisco switch like 3650,3560 or 3750 or is there any additional configuration needed for this, then please let me know.
If you need any additional info like diagram or log then please don't hesitate to contact me.
Waiting for your valuable suggestion.
A
08-29-2016 03:15 AM
If you could post some of the configuration without compromising proprietary data, that would be helpful. I know this is a basic question, but do you have the command "ip routing" present in your configuration?
08-31-2016 12:12 AM
Hi James,
Thanks for your reply. Actually CISCO-3650 is using as core switch for one of our upstream provider. We have configured BGP & Static route on this switch so the command "ip routing" is obviously present there. Right now we have shifted all SVI's to cisco-3550. So if you need the logs to identify the issue then I have to setup the same in cisco-3650 then can only able to send you the log.
Please let me know so I can arrange the same.
Ankan
