02-13-2012 12:59 PM - edited 03-07-2019 04:54 AM
Anyone have any pointers on configuring inter vlan routing on Catalyst 4507 switches
Solved! Go to Solution.
02-13-2012 09:19 PM
You may want to check L3 interfaces page in the document Glen mentioned above and specifically "logical Layer 3 VLAN Interfaces":
That explains how L3 VLAN interface is working to provide following:
The logical Layer 3 VLAN interfaces provide logical routing interfaces to VLANs on Layer 2 switches. A traditional network requires a physical interface from a router to a switch to perform inter-VLAN routing. The Catalyst 4500 series switch supports inter-VLAN routing by integrating the routing and bridging functions on a single Catalyst 4500 series switch.
And there few configuration examples as well.
Please advise if that it is what you were looking for.
Nik
02-18-2012 08:07 PM
Hi John,
You can close this thread pining the right answers for it to be useful in future.
Nik
02-13-2012 02:24 PM
Not sure what you are looking for , here is the complete configuration guide,
02-13-2012 09:19 PM
Nik
02-14-2012 03:53 AM
Thanks, that's what I needed.
02-14-2012 03:55 AM
Thanks, that’s what I needed.
02-18-2012 08:07 PM
Hi John,
Nik
