12-24-2009 03:00 AM - edited 03-06-2019 09:04 AM
Dear Experts,
What is the command to give on interface to block temporary when flooding or loop occure from perticularly interface,
so that's why no effect to other interface users and also connected to server with uplink port. in both the switches
cisco 3550 and 2950.
Thanks in aDV,
Vaib...
Solved! Go to Solution.
12-25-2009 12:35 AM
Hi Vaibhav,
Check out the below link for Port Unicast and Multicast Flood Blocking:-
Hope this solves your query !!
Ganesh.H
12-24-2009 03:30 AM
csawest.dc wrote:
Dear Experts,
Thanks in aDV,
Vaib...
Vaib
shut/no shut on the interface that is causing problems. This is the only way if you have a loop to stop it immediately.
Jon
12-24-2009 03:46 AM
Dear Marshall,
You given me shut/no shut command , that it manualy but i need autometic block or shut that port when flooding or loop occure from that interface.
or what it the command and how to maximum control when floodin or loop occure from perticulary interface.
Thanks in ADV,
Vaib...
12-24-2009 03:54 AM
csawest.dc wrote:
Dear Marshall,
Thanks in ADV,
Vaib...
Vaib
Apologies, didn't realise you wanted to automate it.
Flooding and loops are slightly different. For loop avoidance you want to be looking at BPDUGuard and BPDUFilter -
for flooding you should look at storm control -
Jon
12-24-2009 04:18 AM
Dear Jon,
Now i have one query,
I have 3550 48P switch in this switch interface port frpm int 3 to 48 connected with IP DSLAM. this means many users conneted with one interface in cisco 3550 , that's why i dint configure spanning-tree port fast enable it is disable on per interface,
so now should configure on per port ( port 3 to 48) BPDU filter or BPDU guard ?? or both the command to give on interface ?? global mode ?? which one!!
at present in cisco 3550 i have configured in global mode spanning-tree mode pvst and on per interface i have configuered spanning-tree portfast disable.
so now should i configue on per interface spanning-tree bpdufilter enable and also spanning-tree bpdguard enable when spanning-tree portfast disable ???
What you suggest me what i hve to do ??
Thanks once again!!!
Vaib...
12-25-2009 12:35 AM
Hi Vaibhav,
Ganesh.H
