Community Member
interface configs
why do some routers show "config-int" when you enter interface configuration mode, while others show "config-if"?
1 REPLY
Re: interface configs
Hi Friend,
I think its only a command that's in the designed IOS. May its designed diffrently in some older IOS and that's why it shows you config-int. In any new IOS I havenot seen this command. Is that on a new IOS or an older one. Can you paste the IOS version details?
HTH,
-amit singh
129
