Webcast-Catalyst9k
interface counters are not increasing in cisco 3750 switch
Hi all ,
Interface counters are not increasing in our cisco 3750 switch eventhough traffic is going on .we are running the below version
:c3750-ipservicesk9-mz.122-53.SE2.bin
Am i hitting any bug or something i need to check ?
Vijay
Hall of Fame Super Gold
Possibly, that's a bad IOS version you are running.  Try 12.2(55)SE8.
Post the output to the following commands:
1.  sh interface ;
2.  sh controll e
Thanks Leo for the reply .
We are seeing some minimal counters in physical(trunk) interfaces . But in the vlan interface it is howing 0 only .
We are using this switch for L3 distribution . All users communication needs to come here only for intervlan routing or to internet. But vlan interface is not showing anything ,
show interfaces vlan xx
Vlaxx is up, line protocol is up
  Hardware is EtherSVI, address is
  Description:
  Internet address is  xxx
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 20:03:51
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     230373 packets input, 18484646 bytes, 0 no buffer
     Received 0 broadcasts (176350 IP multicasts)
     194672 packets output, 13500993 bytes, 0 underruns
     0 output errors, 0 interface resets
TRunk interface output :
show interfaces gigabitEthernet
GigabitEthernet is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is
  Description:
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:07, output 00:00:01, output hang never
  Last clearing of "show interface" counters 20:05:21
  5 minute input rate 263000 bits/sec, 298 packets/sec
  5 minute output rate 641000 bits/sec, 396 packets/sec
     38981807 packets input, 6027251659 bytes, 0 no buffer
     Received 776964 broadcasts (504558 multicasts)
     0 watchdog, 504558 multicast, 0 pause input
     86565656 packets output, 32190953094 bytes, 0 underruns
Plz help me on this...
Vijay
You may need to consider upgrading the IOS to something more stable, like 12.2(55)SE8.
Thanks a lot leo . We will upgrade the IOS and will update .
Vijay.
Hello Vijay.
You might be hitting the bug id CSCsu83445.
show interface shows 0 packet in interface input and output rate
Symptoms
: An input/output rate is always displayed with "0" in interface  status, even though packets are flowing on the ports normally.
Resolution:
   Use the value of the show int gigx/y count detail command  to see the raw statistics.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu83445
Anyways consider upgrading the IOS version, 12.2(53) is too old I don't think it has support any more.
Regards.
Wilson B.
Please rate if useful!
Thanks a lot wilson for replying. But this version is not there in affected or found  version of this bug. IS it may be hidden bug like that?
Vijay.
352
