interface fastehernet on router 831
yoyo_the_king
hi,
i want set ip adress to fastethernet port cisco 831 router, but he give this msg:
IP addresses may not be configured on L2 links.
how can i solve this plz.
16 Replies 16
Richard Burts
The 831 router includes the fastethernet ports in a small switch. So the fastethernet interfaces are layer 2 switch ports and you can not configure IP addresses on layer 2 ports. There is a VLAN interface and it is on the VLAN interface that you configure the IP address.
Rick
Rick
hi,
i want connect this router with 2 network.
how can i do this.
what interfaces must be configured?
maybe eth 0 and eth 1 ?????
You are talkin about external and internal network? If so you need configure FA4 interface and Vlan 1 interface ip address that's it
hi,
yes, but there isn't possibility to configure vlan.
he don't accept "interf vlan" command.
what it answerers on command
interface ?
what type of interfaces its support?
this is the answer of "interf ?" :
async , BVI , CDMA-Ix , CTunnel , Dialer , Ethernet , FastEthernet , Group-Async , Lex , Loopback , Multilink , Null , Tunnel , Vif , Virtual-PPP , Virtual-Template , Virtual-TokenRing , range.
sh ver - please past here
this is the result of sh vers:
sh ver
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 26-Jan-07 00:07 by prod_rel_team
ROM: System Bootstrap, Version 12.2(11r)YV5, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 38 minutes
System image file is "flash:c831-k9o3sy6-mz.124-11.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More-- http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
export@cisco.com.
Cisco C831 (MPC857DSL) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FOC10154UCF (1088755702), with hardware revision 0000
Chassis serial number FCZ1017201J
CPU rev number 7
3 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Router#
I suppose you have three L3 interfaces with name E0, E1, E2 and four FA0-4 interfaces on back of your router is that correct?
if so do - sh ip int bri
E0 should same range as all FA ports
E1 will be your external port
yes it's right,
plz, haw can'i connect the router and what interface i must configure?
configure E0 as your internal IF, and E1 as your external IF.
As I remeber E0 share connectivity with FA ports on this model. just try setup ip address on E0 interface connect something on any FA ports and ping E0 IF.
thankyou very much.
i try it and i answer you.
hi,
1)i configure eth0 with 10.5.10.1/24
and i connect pc1 to this interface with 10.5.10.2
2)i configure eth1 with 212.217.93.195/28
and i connect pc2 to this interface with 212.217.93.194
each pc ping his interface.
but i can't ping pc1 from pc2 or inverse.
why.
make sure default getaway set correctly on both pc's
