interface resets causes Port channel to flap nexus 5010
Hi all,
I am having the issues explained below , I did not find any bug related to the below error messages , your help is appreciated.
Here is an example of what each switch logs when a server drops offline.  Sample logs taken between 5:32am and 5:35am on Feb 20.   This particular one was having problems all weekend.  Switch #1 encountered over 2000 interface resets.  The corresponding VPC port on Switch #2 only had 13 resets.
I’d be happy to start a web meeting session with someone to show you more if it helps.
NEXUS SWITCH #1
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
from Ethernet1/10 to none
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:32:09 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
No operational members)
2012 Feb 20 05:32:09 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
Control state changed to off
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
w Control state changed to off
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
ow Control state changed to off
2012 Feb 20 05:32:20 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:32:20 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
from none to Ethernet1/10
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
eing suspended. (Reason: Vlan is not allowed on Peer-link)
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:33:22 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
2012 Feb 20 05:33:22 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
2012 Feb 20 05:33:33 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:33:33 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:34:35 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
2012 Feb 20 05:34:35 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
2012 Feb 20 05:34:46 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:34:46 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:35:48 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
NEXUS SWITCH #2
2012 Feb 20 05:32:20 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
oved from suspended state.
2012 Feb 20 05:32:20 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:33:33 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:33:33 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:34:46 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:34:46 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:35:59 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:35:59 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
1 REPLY
Hi Saleem
It seems like port-channel 10 has only one link ethernet1/10 - and it flaps. Most probable cause - cble defect or sfp module defect. Start troubleshooting from replacing them.
If po10 is peerlink, and vlan 999 is only allowed vlan,  it flaps -  secondary peer will suspend vlan because it's not allowed on peerlink.
But there might be other scenarios.
Try to replace mentioned parts and then check.
HTH,
Alex
3169
