Interfaces on standby Supervisor Engine IV
On a Cisco 4507 with Redundant Supervisor Engine IV. Can the Interfaces/GBIC on the standby Supervisor be used or can you only use interfaces on the current active supervisor. I cant find any documentation on this.
Kev
1 ACCEPTED SOLUTION
Silver
Re: Interfaces on standby Supervisor Engine IV
The first module on both Supervisor engine would be active. The second module on both Supervisor engines will not be accesible.
This document should help you http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080134f18.shtml#topic2
Hoogen
Do rate if i have helped :)
Silver
Hoogen
Cheers for that its just what I was looking for
113
