Internet - 3550 - Vlans
I'm playing with a 3550 switch.
I have created several vlans and can ping between those.
If I go onto the switch I can ping the gateway and the internet.
If I go on to a host connected to one of the vlans and try and ping the internet I get nothing.
The switch is attached to a router with the ip address 192.168.0.1. I've done the no switchport command on the interface and again I can ping anything from the switch I just can't ping from a host through the switch.
What have I done wrong?
Thanks.
3550#show run
Building configuration...
Current configuration : 3707 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3550
enable secret 5 $1$YB2k$xsUyU5VDRZiEEaMgew45W0
username libby password 0 libby
no ip subnet-zero
ip routing
ip dhcp pool wireless
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   domain-name wireless
   dns-server 8.8.8.8
ip dhcp pool vlan3
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   domain-name accounts
   dns-server 8.8.8.8
ip dhcp pool vlan4
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
   dns-server 8.8.8.8
   domain-name marketing
ip dhcp pool vlan5
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   dns-server 8.8.8.8
ip domain-name test
spanning-tree mode rapid-pvst
spanning-tree vlan 1 priority 24576
interface FastEthernet0/1
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 2
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 3
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 4
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 5
interface FastEthernet0/10
interface FastEthernet0/11
switchport mode dynamic desirable
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
bandwidth 10
interface FastEthernet0/23
switchport access vlan 6
interface FastEthernet0/24
no switchport
ip address 192.168.0.2 255.255.255.0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.0.1.234 255.255.255.0
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan3
ip address 192.168.3.1 255.255.255.0
interface Vlan4
ip address 192.168.4.1 255.255.255.0
interface Vlan5
ip address 192.168.5.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
Everyone's tags (1)
1 ACCEPTED SOLUTION
Can you set the static routes on your router? If not, can a routing procotocol be configured on this router? Unless the router knows how to get to these subnets, it wont be able to forward the traffic towards 3550.
The only way you can make it work either
1. Have the static routes on the router for the subnets configured on the 3550 switch?
2. Run a routing protocol between 3550 and the router and include the subnets that you ahve configured on the 3550 under the routing proctocol config.
3. Have a single vlan configred and have all the hosts connected to this vlan only.
Hope this helps.
-amit singh
Hi Andrew,
What is the Default Gateway on the host? Have you checked that the correct gateway is assigned?
Does you router has reverse static routes towards 3550 switch to reach the subnets configured on the 3550?
Also, Please could you paste " show ip route " from both the 3550 and router.
-amit singh
Thanks for the reply. The default gateway on the host is set by the dhcp as per the show run. The hosts seem to be able to communicate between each other fine, ping the switch etc.
The router is just a home router so can't post the config.
I think you are on to something re the reverse routes. I don't have any! I just plugged the home router into fa0/24, can I not do that?
Will post show ip route etc in a bit.
Did you set the def gw on the host correctly?
regards,
Leo
where is you NAT configuration ? post router config as well.
Purple
He can't have a NAT configuration on a 3550  He must be doing the NAT on the router
Regards.
Alain
Agree i asked for router config only .
Hope this helps.
-amit singh
Thanks very much for your quick reply.
I will take a look at that in a bit.
It was the routes on the other router. I was being a moron and over looked the simply stuff.
Thanks again!
No worries Andrew. Glad it worked. Thank you for using the rating system and marked the post as answered.
Please feel free to post any questions that you have doubts on.
Cheers,
-amit singh
665
