11-03-2010 04:10 AM - edited 03-06-2019 01:51 PM
Cisco router in Melbourne is disconnecting more frequently Apparently it disconnected 4 times today, If it is restarted then it works again for a while, but eventually it disconnects from the internet and doesn’t attempt to reconnect
Can anyone help me ? this router has been a problem never have managed to get it to be reliable
the question is whether there is a hardware problem or a config problem
im sure the internet stops and starts all the time but this router doesn't appear to reconnect
also if swap router to BILLION from Cisco then all is fine
interface Dialer0
mtu 1454
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username XXXXXXXXXXXXXXXXXXX password XXXXXXXX
Warm Regards
Vikrant
11-03-2010 04:20 AM
Hello
Do you have any logs regarding the reason why it get disconnected?
Calin
11-03-2010 04:35 AM
Thanks for your quick reply, I didn't get ant error or any log, i am not sure why,
if it's disconnects from the internet and doesn’t attempt to reconnect, it should be connect Automatically, but if i restarted manualy by using power switch then it works again. I am very much irritate from this issue it will be a great if you will help me, i did post this issue on many forums but same issue yet
Pls look logs
Cisco877#sh log
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 50 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 50 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level informational, 54 message lines logged
Logging to 192.168.8.12 (udp port 514, audit disabled,
authentication disabled, encryption disabled, link up),
54 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Log Buffer (4096 bytes):
el_team
*Mar 4 03:28:18.331: %SNMP-5-COLDSTART: SNMP agent on host Cisco877 is undergoi
ng a cold start
*Mar 4 03:28:18.379: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar 4 03:28:18.383: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client) User= Group=EZ
VPN_GROUP_1 Server_public_addr=XX.XX.XX.XX
*Mar 4 03:28:18.431: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning freque
ncies for 35 seconds
*Mar 4 03:28:18.435: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 4 03:28:18.435: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Mar 4 03:28:18.439: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Mar 4 03:28:18.455: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 4 03:28:18.455: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar 4 03:28:18.483: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.8.12
port 514 started - CLI initiated
*Mar 4 03:28:19.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to up
*Mar 4 03:28:19.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Mar 4 03:28:19.871: %LINK-5-CHANGED: Interface NVI0, changed state to administ
ratively down
*Mar 4 03:28:19.999: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to
up
*Mar 4 03:28:19.999: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to
up
*Mar 4 03:28:19.999: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar 4 03:28:20.871: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan
ged state to down
*Mar 4 03:28:20.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et3, changed state to down
et2, changed state to up
et1, changed state to down
et0, changed state to down
*Mar 4 03:28:24.463: %PKI-6-AUTOSAVE: Running configuration saved to NVRAM
*Mar 4 03:28:40.511: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*Mar 4 03:28:41.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, chan
ged state to up
*Mar 4 03:28:55.343: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Mar 4 03:28:55.359: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up
*Mar 4 03:28:56.483: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Ac
cess1, changed state to up
*Mar 4 03:28:56.619: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2412
selected
*Mar 4 03:28:56.623: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 4 03:28:57.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar 4 03:29:00.415: %CRYPTO-6-EZVPN_CONNECTION_UP: (Client) User=vpnadmin Gr
oup=EZVPN_GROUP_1 Client_public_addr=XX.XX.XX.XX Server_public_addr=XX.XX
XX.XX NEM_Remote_Subnets=192.168.8.0/255.255.255.0 192.1
*Mar 4 03:33:28.127: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et2, changed state to down
*Mar 4 03:33:28.127: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to down
*Mar 4 03:33:29.131: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
down
*Mar 4 03:33:33.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to up
*Mar 4 03:33:34.075: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
up
*Mar 4 03:33:35.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Mar 4 03:33:51.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Mar 4 03:33:51.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to down
*Mar 4 03:33:52.667: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
down
*Mar 4 03:33:55.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to up
*Mar 4 03:33:56.227: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
up
*Mar 4 03:33:57.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
Cisco877#
11-03-2010 05:08 AM
hi,
i've observed bouncing more on the LAN FE ports. what devices are connected behind your 877? if WAN is still intermittent, i would suggest to try replacing the RJ-11 cable or try connecting directly to the phone wall socket without the the splitter or fax connected with it. lastly if all still fails, ask your ISP to have a technician to inspect for any wiring problem.
11-03-2010 08:57 PM
Thanks for giving comment, we are mostly using wi- fi, only two system are connected to FE LAN ports by RJ-45, we have issue in All System (WI-FI also LAN), If restarted Cisco Router then it works again for a while, but eventually it disconnects from the internet and doesn’t attempt to reconnect
if I change router menas swap to Billion Router then all is fine,
Please look on Snap when i lossed internet
11-04-2010 02:44 AM
04-05-2020 03:22 AM
Hi Sir,
I have the same issue could you please give advise how to reduce DB, I would like to try this one at least.
Appreciated.
