InterVLAN Multicast
challc2008
We have 2 VLAN's setup on a Cisco 4500 series switch that is running Cisco IOS. We are using Symantec Ghost and it is working fine on a single VLAN, however Multicast traffic is not crossing over to the other VLAN. Any links and/or pointers will be greatly appreciated. Thank you in advanced.
"I only enabled "ip pim spase-dense-mode" under VLAN 2 (sorry do I need to also enable it on the VLAN where the ghost server is?)"
Yes you do. All vlan interfaces that the multicast packets travel across need to have the pim configuration under the vlan interface.
Jon
15 Replies 15
schmij01
You need to enable multicast routing with PIM on the two vlan interfaces. You probably need the IP Services image (or equivalent) to use PIM though. Ie.
interface vlan 100
ip pim sparse-dense-mode
Jon Marshall
Things to check
1) Have you enabled multicast routing on the switch. If yes
2) Is the TTL of the multicast packet greater than 1
if not to 1 then
4500(config)# ip multicast-routing
and then on under each vlan interface you want to enable multicast on
int vlan
ip pim dense-mode
note you can use sparse-mode if you want but you need additional configuration. The above should at least let us know if the above is the problem.
Jon
Good catch on the TTL and enabling multicast routing if not already enabled.
Thank you for the reply, I did run the command to enable multicast on the switch how do I find out the TTL?
The application itself sets the TTL - it may be an option in the app setup. Sorry not familiar with Ghost.
Edit - just found another thread that suggests that Ghost does indeed set to TTL to 1 by default so there must be an option to set it higher. If all devices are on the 4500 switch then a value of 2 will do. If some of the devices are hanging off access switches then you may want to look into sparse mode as apparently Ghost imaging generates a lot of traffic and you could overwhelm some of your links.
Jon
Thank you again for the reply so basically I should under each vlan run:
And that should let the multicast traffic go from one VLAN to the other correct?
Only add it under vlan interfaces that have devices within that vlan that want to receive the multicast stream.
Jon
Thank you I just did that, eh but unfortunately will have to wait for our server guys to test it on Monday and let me know if it worked on not. I will update you guys on Monday. Thank you again and have a great weekend.
No problem. But note that you still need to increase the TTL which i assume is something your server guys will have to do.
Hope it works.
Jon
Ok I have an update on this, after adding those options it is still not working. When I run ghost it can not find the clients on the other VLAN.
This is what "sh int vlan 2" gives me:
#sh int vlan 2
Vlan2 is up, line protocol is up
Hardware is Ethernet SVI, address is 0002.fc32.d7ff (bia 0002.fc32.d7ff)
Internet address is 10.5.9.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:08, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 55000 bits/sec, 16 packets/sec
5 minute output rate 161000 bits/sec, 17 packets/sec
L3 in Switched: ucast: 5826588 pkt, 1563654138 bytes - mcast: 719 pkt, 194230
bytes
L3 out Switched: ucast: 6554334 pkt, 4409882188 bytes - mcast: 0 pkt, 0 bytes
5827307 packets input, 1563848368 bytes, 0 no buffer
Received 12824 broadcasts, 0 runts, 0 giants, 0 throttles
6554334 packets output, 114914892 bytes, 0 underruns
0 output errors, 0 interface resets
So to recap :)
1) Your switch has "ip multicast-routing" enabled.
1) Under each vlan interface you have
int vlan x
note - try changing this to just
ip pim dense-mode
as an additional test. We can change back later.
2) You have IGMP snooping configured in the switch
3) You have increased the TTL for the multicast Ghost packets to above 1. This figures needs to be equal to number of hops + 1. So if client vlan is another directly connected vlan on the 4500 then ttl would be 2.
What is the group membership address Ghost is using ?
Jon
1- Yes "ip multicast-routing" is enabled
1- I only enabled "ip pim spase-dense-mode" under VLAN 2 (sorry do I need to also enable it on the VLAN where the ghost server is?)
2- IGMP information:
#sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
239.255.255.253 Vlan2 3d20h 00:02:12 10.5.9.62
239.255.255.250 Vlan2 3d20h 00:02:09 10.5.9.62
224.0.1.40 Vlan2 3d20h 00:02:18 10.5.9.1
224.0.1.60 Vlan2 3d20h 00:02:19 10.5.9.57
#sh ip igmp snooping
vlan 1
IGMP snooping is globally enabled
IGMP snooping TCN solicit query is globally disabled
IGMP snooping global TCN flood query count is 2
IGMP snooping is enabled on this Vlan
IGMP snooping immediate-leave is disabled on this Vlan
IGMP snooping mrouter learn mode is pim-dvmrp on this Vlan
IGMP snooping is running in IGMP_ONLY mode on this Vlan
IGMP snooping report suppression is enabled on this Vlan
vlan 2
Jon
Duh my bad sorry that was stupid of me :-(. But thank you so much you are a genius, it is working now :-).
