04-28-2008 03:21 AM - edited 03-05-2019 10:39 PM
Is it possible two configure Inter VLAN Routing ( Router on a Stick ) and LAN WAN Routing in a single Router.
Pls Help
Anish N
04-28-2008 06:13 AM
Anish
Try changing "ip unnumbered gi0/0" under your serial interfaces to "ip unnumbered gi0/0.1"
Jon
04-28-2008 06:19 AM
Thanks jon,
It is not possible for me to make changes in the router as the office is closed. I will make the changes tomorrow morning, and let you know the result.
Anish
04-28-2008 06:06 AM
Dear Jon,
Thanks for your kind support.
Sorry, I have to leave now, as the office is closed now, Can you pls post the timing of your availability for tomorrow.
Thank you once again for your kind support.
Anish
04-28-2008 04:08 AM
I would like to suggest why dnot u use u r 3750 for intervlan routing.
From where u r trying to get in to the router.?
If from any port on the switch check the config of the switch and ur default-gateway should be sub-interface of the router.
Mahmood
