InterVlan Routing On L3 Switch and NAT On another Router
Hi All,
Not sure if this can be done
ISP----------Router--<L3 Port>--L3 SW--------------------Intenal Network
Router Config:
access-list 1 permit 192.168.0.0 0.0.0.3
access-list 1 permit 10.0.0.0 0.0.0.255
ip nat inside source list 1 interface <WAN> overload
interface <WAN>
ip address 1.1.1.2 255.255.255.252
ip nat outside
no shut
interface <LAN>
ip address 192.168.0.1 255.255.255.252
ip nat inside
no shut
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 10.0.0.0 255.255.255.0 192.168.0.2
Switch Config:
ip routing
interface fa0/1
no switchport
ip address 192.168.0.2 255.255.255.252
no shut
interface VLAN 10
ip address 10.0.0.1 255.255.255.0
no shut
interface range fa0/2-24
switchport
switchport mode access
switchport access vlan 10
spanning-tree portfast
no shut
From the PC, I am not able to access the internet. nor can i do a NAT translation on WAN Router.
WHY?
btw, Layer 3 Switch does not allow us to configure NAT.
Help is greatly appreciated.
Yen Lung
Hall of Fame Super Blue
Re: InterVlan Routing On L3 Switch and NAT On another Router
Hi Yen
Do you have a deault route on your L3 switch pointing to 192.168.0.1 ?
Jon
Oh yes, I had put it down in my config.
Still not working...
Hi Yen.
- Can you do ping command from hosts to 192.168.0.1.
- Can you resolve names from the DNS server?
From hosts : C:\>nslookup http://www.google.com
Hopes that help
Thot
i had forgetten the ip route on the above.
I had put that in in my L3 SW.
I could not test that, as it is a internal Lab.
but, from the PC, I am able to ping to the WAN Interface.
No NAT translation.
Any one can help me with this?
It seem to be a simple problem. what am i missing?
Hi yen
Firstly are you sure packets are getting to the router from the switch.
if so, can you run a "debug ip nat" on the WAN router to see what is happening.
Be careful with debug commands as they can affect the performance of the router.
Jon
Ok ... Problem solved,
One quick question...
When I ping the WAN Router Outside interface, from the Inside Interface, I get a NAT translation.
however, once i go to the l3 switch, and ping the WAN router outside interface, I do not get a NAT translation.
WHY?
173
