Introduce second default gateway into policy-based routing and optimization
Questions:
1) How to get the second PBR_DEFAULT_GATEWAY address 10.20.20.3 into the policy-based routing for redundancy?
2) Any optimizations as more and more traffic (policy-based routed and otherwise) goes through interface Gi1/0/1?
Address range A.B.0.0/16 represents assigned Internet-routable addresses.
Network also uses 10.0.0.0/8, 172.16.0.0/20, 192.168.0.0/16.
DEFAULT_GATEWAY router participates in OSPF and injects the default routes 0.0.0.0/0 10.10.10.1 and 0.0.0.0/0 10.20.20.1 into OSPF.
PBR_DEFAULT_GATEWAY router participates in OSPF but filters out default routes injected by DEFAULT_GATEWAY router.
ROUTER_A participates in OSPF and receives default routes injected by DEFAULT_GATEWAY router.
ROUTER_A contains the attached policy-routing configuration that allows the subnet A.B.30.0/24 to route anywhere on the network and uses PBR_DEFAULT_GATEWAY as the way out.
Everyone's tags (1)
76
